ABS brake line fitting size - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ABS brake line fitting size
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-31-2015, 10:08 PM   #1
billj
Hi All,
I replaced all the hard lines on my 97 TJ with ABS using a non ABS kit (I thought there was no difference). I need to know what size and this last fitting is and to confirm the double flare. It's for the rear line. I reused one fitting with the help of a neighbor mechanic. This last one does have a course thread, I tossed the original fitting. Thank you all.
billj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:51 AM   #2
682bear
I'm not sure exactly what size that particular fitting is, but all the ABS fittings are metric fittings, where the rest of the lines use standard fittings...
-Bear
682bear is offline   Reply With Quote Quick reply to this message
