? about Skyjacker Shocks - JeepForum.com
post #1 of 11 Old 02-14-2013, 07:24 PM Thread Starter
dbabicky
1975 J-Series Truck
Can you run the Sky Jacker Nitro shocks upside down? (Piston rod down)
Why me, Why me !!!
dbabicky is offline
post #2 of 11 Old 02-14-2013, 08:31 PM
rubidriver
I have seen people do it, but I don't recommend running a twin tube shock with the canister up.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #3 of 11 Old 02-14-2013, 11:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I thought their Nitro shock was a monotube.
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 11 Old 02-15-2013, 07:16 PM Thread Starter
dbabicky
1975 J-Series Truck
The reason I asked the question is that I did a 2" BB with Skyjacker Nitro shocks to my 1998 TJ Sport. It looked really tight for the rear shocks, so we mounted them upside down to give us a little more room.
Now the Jeep rides like it has no/worn out shocks in the rear. It's very "Bouncy" in the rear.
Is this a "upside down" shock issue or traits of the 2" BB? The front rides fine, but the shocks are mounted right side up.
Thanks in advance.
Why me, Why me !!!
dbabicky is offline
post #5 of 11 Old 02-15-2013, 07:20 PM
tyvanwie
Put them right side up. Why do you need more room anyway?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #6 of 11 Old 02-15-2013, 11:29 PM
rubidriver
No Jerry, just because they are charged has nothing to do with the internals. They are basically the same shock as a hydro with some gas charge behind it. Still the crappy twin tube design. Hated both my hydro and nitro sets.... Heres some info
Nitro shocks from Skyjacker are designed to adjust automatically to any on or off-road conditions. They feature 150 psi pressurized nitrogen gas, twin-tube construction, and multi-stage, velocity-sensitive valving. These shocks also have an oversized piston head and a 14mm piston rod. They come standard with red polyurethane bushings and boots, and they look great and make your ride smoother, whether you're on the trail or the open road.
post #7 of 11 Old 02-17-2013, 09:56 AM
Jerry Bransford
Administrator
The rear shocks are commonly inverted to provide more clearance between them and the lower spring perch after the axle is rotated to raise the pinion angle for a CV driveshaft.
I believe you, I had only found the monotube version of their gas charged shocks on their website when I was looking for more info sometime back. They definitely also have a monotube version of gas charged shock.
Getting
post #8 of 11 Old 02-17-2013, 12:07 PM
JBTJ
Thanks in advance.
Yes
JBTJ is offline
post #9 of 11 Old 02-17-2013, 12:13 PM
BLK00TJ
... make your ride smoother, whether you're on the trail or the open road.
This part made me laugh.
BLK00TJ is offline
post #10 of 11 Old 02-17-2013, 01:40 PM
rubidriver
Same here. I just cut and pasted that off the website.
post #11 of 11 Old 02-22-2013, 10:53 PM Thread Starter
dbabicky
1975 J-Series Truck
Yes, I have proven it to myself. Sky Jacker Nitro's do not work in the upside down position. Installed them right side up,(rod end up), they work as advertised.
Why me, Why me !!!
dbabicky is offline
