AA linkage bracket/ linkage adjustment? - JeepForum.com
post #1 of 2 Old 06-01-2007, 12:57 AM Thread Starter
Wrangler11
Wrangler11's Avatar
Kerndone and I just finished installing my SYE and also threw on the AA linkage bracket. What a pain in the neck. I'm sure Kerndone will have better input on the problem then I will, but I'll give it a shot. We were unable to adjust the linkage. It would not adjust no matter what we tried. We had the rear end of the jeep on ramps. It seemed to switch between 2h, 4H, N, 4L fine. When I went in the jeep to bring it off the ramps I could not get it out of 4l. We pushed the jeep back a little and it ended up going into 2H pretty easily. Were not sure if it needs to be adjusted or if it was just in a bind. I have to be at work early tomorrow and it was getting late so I didn't want to try and go through 2h, 4h, n, 4l and have a problem with it again. If it turns out that it does need to be adjusted is a trick to get it to work?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #2 of 2 Old 06-01-2007, 08:56 PM Thread Starter
Wrangler11
Wrangler11's Avatar
Anyone........
Tcase Linkage adjustment taftech TJ Wrangler Technical Forum 5 01-15-2010 05:14 PM
4wd shifter linkage adjustment That1guy TJ Wrangler Technical Forum 7 08-17-2008 01:58 PM
t case linkage adjustment chutta TJ Wrangler Technical Forum 2 05-07-2007 09:34 AM
T-Case linkage adjustment Lud04X TJ Wrangler Technical Forum 2 09-20-2006 07:45 AM
shifter linkage adjustment padkisson621 TJ Wrangler Technical Forum 6 02-11-2006 10:37 AM
