99 wrangler steering gearbox issue - JeepForum.com
post #1 of 4 Old 12-16-2012, 05:02 PM Thread Starter
Cragg
The gearbox on my 99' wrangler sport has about an inch of play in the steering... Does any1 kno if this is an easy fix or not?
Cragg is offline
post #2 of 4 Old 12-16-2012, 05:43 PM
UTWeezul
Are you sure it is the gearbox? Have you checked all the tie rod ends for play? I'd have someone get in the Jeep and rock the steering wheel back and forth while you lay under it and look for play in all the TREs first. Replaced them is easier and cheaper. Also make sure all the bolts are tight. This will cause play as well.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is online now
post #3 of 4 Old 12-16-2012, 06:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
An inch of play where? Do you mean you can turn the steering wheel back & forth without the Pitman arm moving?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #4 of 4 Old 12-16-2012, 06:29 PM Thread Starter
Cragg
Yea i can turn the wheel to the left and the right about an inch without anything moving... i apoligize if im not being specific enough i dont kno to much about these things
Cragg is offline
