99 Wrangler Sport with some rust - JeepForum.com
post #1 of 8 Old 08-05-2010, 09:24 AM Thread Starter
bharkin
I am looking at a 99 Wrangler, under the hood there is some rust on the the brake booster, brake lines, battery tray, etc. Is this a sign to stay away or not so bad?
[IMG][/IMG]
Thanks for the help!
bharkin is offline
post #2 of 8 Old 08-05-2010, 09:35 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Is it surface rust or are things falling apart?
Lots of my older vehicles have a light coating of rust on things, but don't appear to be eaten away.
I'd make sure the frame and undercarriage aren't rotting away.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #3 of 8 Old 08-05-2010, 09:39 AM Thread Starter
bharkin
I'm going over this afternoon to look at it, I found it online. From the pics I've seen, it looks good. I plan on a thorough inspection, but I have never owned a Jeep before and was just wondering if the amount and location of the rust on the engine was something to worry about.
bharkin is offline
post #4 of 8 Old 08-05-2010, 09:39 AM
bairy
Looks somewhat normal to me.. (NY & OH)
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #5 of 8 Old 08-05-2010, 09:46 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Went out and looked at my friends 97 and it has similar rust.
It wouldn't deter me from buying it.
MAMMOTH is offline
post #6 of 8 Old 08-05-2010, 09:52 AM
Coop02x
Like others have said, I would make sure the frame, tub, or other major components of the vehicle didn't have anything that was rusting through. Some surface rust isn't that big of a deal; you can just clean it up and put some paint on it.
If it has carpet, be sure to take a look up under it to make sure floor pans are in decent shape.
Good luck! Hope it works out for you!
Coop
Coop02x is offline
post #7 of 8 Old 08-05-2010, 09:56 AM
herbiehind
x2 the lines are easy replace . use a welders' pick or hammer on the frame and listen to the steel . if it sounds like a bell everywhere it's good it it goes to a different pitch and there is scale there then you gotta look closer and see how soft .
herbiehind is offline
post #8 of 8 Old 08-05-2010, 10:29 AM
Nonya
Its a sign its a real jeep LOL They ALL need the brake lines replaced because they rust badly. The local jeep dealer told me to buy a aftermarket kit because the replacement jeep lines will just rust again. I had to use buy the factory lines because i have ABS and no aftermarket company makes replacement lines.
I would check the frame VERY carefully, the 97 i bought had a bad frame and it was hard to see until I really checked it out. Looking for another jeep I checked the frames 1st and you would be suprised the low mileage jeeps i found with major frame damage.
The frames on these TJ's are fully inclosed along the center section. The HUGE INSANE holes in the sides of the frame allow dirt water salt etc into the frame but there are no drain holes to let it back out. SO after a while you can imagine the damage.
Look closely inside the large hole near the rear wheels on the side of the frame. If there is all kinds of rust and debris inside i'd stay away from it. My 97 was FULL of rusted metal from the inside of the frame....seems jeep didn't paint the inside!!!!!!!! or dip the frames for rust protection like you would expect.
PS ya know Toyota replaced the frames on low mileage trucks that had rust damage.
Nonya is offline
tj , wrangler , rust
Should I buy this TJ sport with this much rust. Ewen91 TJ Wrangler Technical Forum 16 08-03-2010 09:14 PM
help on 98 wrangler (rust on frame) sullyd51 TJ Wrangler Technical Forum 15 06-10-2010 07:24 AM
Wrangler Rust Justin1805 YJ Wrangler Technical Forum 2 07-16-2008 06:47 PM
1998 wrangler sport vs. 2000 wrangler sport David Hinton TJ Wrangler Technical Forum 15 02-13-2007 11:54 PM
Rust on the door hinges? ('03 Sport) AggieTJ TJ Wrangler Technical Forum 4 07-11-2003 08:17 AM
