99 TJ Turn Signals & Hazard Lights - JeepForum.com
post #1 of 9 Old 06-28-2010, 11:04 AM Thread Starter
shaunmfink
Before I start let me say I've just found this forum so please excuse any new post-er mistakes.
I've searched the FAQ and the forums, found similar issues but not quite the same.
So here it is .... I have a 99 and my turn signals & hazard lights are inconsistently working / not working. Here are the scenarios - I think its a connection or electrical issue somewhere (admittedly I don't know much about these types of things).
The left turn signal works consistently. Sometimes it blinks really fast, other times normal. But seems to consistently come on.
The right turn signal doesn't work.
The hazard lights are intermittent. Wiggling the hazard switch can make them come on if they are off and vice versa (not all the time, but sometimes).
Sometimes when I turn the hazard lights on, then off, the right turn signal will then work.
I've checked the fuses behind the glove box and they seem to be fine. Not sure what else to check - if there is anything I can do to provide more info let me know.
Appreciate any thoughts or feedback.
- SMF
shaunmfink is offline
post #2 of 9 Old 06-28-2010, 11:07 AM
biffgnar
biffgnar's Avatar
Sounds like your flasher relay might be bad.
Romney in 2020!
biffgnar is online now
post #3 of 9 Old 06-28-2010, 11:20 AM Thread Starter
shaunmfink
Thanks biffgnar - really appreciate the insight. Do you know any way to test or should I just pick one up and give it a shot? Also - is this something I can find at a local parts store (i.e. autozone) or a specialty shop?
- SMF
post #4 of 9 Old 06-28-2010, 11:22 AM
andy02
You can get it at any parts store. No real test for it and the flasher shouldn't be that expensive. Give it a shot. If it doesn't work, come back and let us know. We will keep troubleshooting.
Oh, and welcome to the forum!
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #5 of 9 Old 06-28-2010, 11:24 AM
TJaefick
Could also be the multi switch in the steering column. If it is the flasher relay, they aren't expensive and most auto parts store have them. It's located under the dash and you can hear it clicking when the flashers are on (or turn signal if it's working).
'05 LJ, 2" OME, ARB/4.56, 33x12.5
TJaefick is offline
post #6 of 9 Old 06-28-2010, 11:31 AM Thread Starter
shaunmfink
Thanks everyone. Really appreciate the insight. I'll pick up a flasher relay this afternoon and let you know how it goes.
- SMF
post #7 of 9 Old 06-28-2010, 11:36 AM
Cuder
X2 on the multi fuction switch not working right.
Cuder is offline
post #8 of 9 Old 06-29-2010, 02:59 PM Thread Starter
shaunmfink
Can one of you all help me with which flasher relay I need - I found two versions. One has five terminals, another four. I read a little online and apparently the five terminal module is the newer version (so I assume better) - but not sure if the two modules are interchangeable?
Appreciate the help.
- SMF
post #9 of 9 Old 07-02-2010, 01:15 AM
TJaefick
Four-pronged relays are 97-00. The 01's and up are five. Not sure about their interchangability, but I would assume you should go with the year of Jeep. Please fill out your profile.
TJaefick is offline
turn signal , flasher , relay
'88 YJ hazard lights won't turn off! SamzJeep YJ Wrangler Technical Forum 7 04-14-2013 08:47 AM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Need Help, Brake lights/turn signals Bugz2oo2 TJ Wrangler Technical Forum 5 08-29-2006 01:56 AM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
No turn signals or Brake lights Patton TJ Wrangler Technical Forum 1 09-10-2002 06:45 AM
