99 TJ Starting Issues - JeepForum.com
post #1 of 3 Old 08-04-2013, 04:55 PM Thread Starter
ThePhakeMcCoy
When the engine is cold, my Jeep starts right away, but after it warms up and say I go into the store for 10 minutes and come back to crank it, it takes a while to finally turn over, or I cut the switch all the way off and turn it back on and it will fire right up. A buddy of mine, told me it was the fuel pressure regulator, as he has replaced his twice. I changed that and the issue is still there. I had the fuel pressure checked and it is okay.
Anymore ideas on what could be causing this? I was told possibly the crank sensor?
ThePhakeMcCoy is offline
post #2 of 3 Old 08-06-2013, 09:38 AM
PentiumJoe
PentiumJoe's Avatar
I have a similar issue. Any advice on this would be appreciated.
2013 J/K Wrangler Rubicon
AEV 2.5 inch lift
35X12.5X17 Discoverer Tires
AEV Black Pintler Wheels
TruckLight LED's
AEV Differential Guard
Warn Premium Front Bumper
Warn (9000LB) Winch
PentiumJoe is offline
post #3 of 3 Old 08-06-2013, 10:23 AM
Jonny Jeep
Jonny Jeep's Avatar
Something is getting heat soaked. Could be many things, bad contact at the battery, bad or loose positive/ground cables, bad CKP sensor, bad wiring splice. Start by removing the clamps from the battery terminals, clean the terminals and clamp contact surfaces till they are shiny and bright, and fasten them back up tight enough that they can't be shifted. If that doesn't make a difference check/clean the other ends of the battery cables. Hopefully it is something simple like dirty battery terminals/clamps.
Jonny Jeep is online now
crank sensor , starting issue , tj
