99 TJ Owners Manual question: Oil - JeepForum.com
 8Likes
post #1 of 20 Old 09-20-2017, 07:14 PM Thread Starter
jeepsgotnutz
Misplaced the owners manual. Dealer put in a different grade of oil than normal.
Need to know what weight oil the owners manual calls for.
You can't have Manslaughter without Laughter
I was sad because I had no shoes, until a I met a man with no feet. So I said to the man, "Got any shoes you're not using?"
jeepsgotnutz is offline
post #2 of 20 Old 09-20-2017, 07:56 PM
zipman35
Look like 10w30
https://***************.com/attachme...ual-pdf.14034/
Sent from my iPhone using Tapatalk
zipman35 is offline
post #3 of 20 Old 09-21-2017, 07:02 PM
SerenityJeepTJ
5W30
"What we think, we become." Buddha
SerenityJeepTJ is offline
post #4 of 20 Old 09-21-2017, 08:04 PM
2jhanna
Originally Posted by SerenityJeepTJ View Post
5W30
Where did you get this from?
Use 6qts of 10/30, brand not that important.
jhanna
denton county, tx
2jhanna is offline
post #5 of 20 Old 09-21-2017, 08:10 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My owners manual lists both 5W-30 and 10W-30. I'm thinking of switching to 5W-30 since it flows throughout the engine more quickly and easily when cold. Both of course are 30 weight viscosities when up to temperature.
arg0413 likes this.
Jerry Bransford is offline
post #6 of 20 Old 09-21-2017, 08:17 PM
2jhanna
My manual states 10/30 preferred, and shows a chart where 10/30 covers from 0 degrees to over 100degrees.
And 5/30 covers from 32 degrees to below -20 degrees.
The OP did ask what the manual stated.
Now we all know we are splitting hairs here and to the OP, if the shop put anything from 5/30 to 10/40, I wouldn't be to worried here in Texas.
jhanna
denton county, tx
2jhanna is offline
post #7 of 20 Old 09-21-2017, 09:16 PM
Jerry Bransford
Administrator
And 5/30 covers from 32 degrees to below -20 degrees.... (and to over 100 degrees as well.)
Clarified.
post #8 of 20 Old 09-21-2017, 09:31 PM
mukluk
Further clarification...
My 2000 owner's manual shows 5W-30 as acceptable for temps 100F and cooler, but the 2005 owner's manual shows 5W-30 acceptable only for temps below freezing. Both state 10W-30 is the recommended viscosity, and is preferred for all temps above 0F.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #9 of 20 Old 09-21-2017, 09:39 PM
Jerry Bransford
Administrator
Originally Posted by mukluk View Post
... but the 2005 owner's manual shows 5W-30 acceptable only for temps below freezing.
You're misinterpreting the chart.
post #10 of 20 Old 09-21-2017, 09:59 PM
mukluk
Seems pretty straightforward to me, 10W-30 is preferred, 5W-30 isn't recommended unless the temps expected before the next oil change are below freezing. I realise both oils get no thinner than a 30wt when hot, but where they differ is the viscosity when cold. Based on the manufacturer's recommendation chart stating 10W-30 is preferred over 5W-30 for anything over 0F, I get the impression that in that temperature range 5W-30 is considered too thin... a hunch tells me the somewhat loose tolerances in our dated engine designs neccessitate the more viscous film of the thicker oil.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #11 of 20 Old 09-21-2017, 10:14 PM
Jerry Bransford
Administrator
It's clear you don't understand how viscosities work then. Both have the exact same 30 weight viscosity once warmed up.
arg0413 likes this.
post #12 of 20 Old 09-22-2017, 12:01 AM
mukluk
Reread the second sentence from my last reply.
I do understand viscosities. I understand both oils are the same when warmed up. I understand the 5wt is thinner than the 10wt when cold. What I'm saying is the thicker 10wt when cold may be needed to sustain proper lubrication inside the engine prior to a cold engine start due to the tolerances in our engines, ie, the 10W-30 is more likely to stay put where it's needed than the 5W-30 in warmer temps. Make sense? Something you may want to consider is what would be the reason the factory changed the temperature range for 5W-30 in their chart, and why did they always insist 10W-30 was the preferred weight?
In the long run people are more than welcome to use whatever oil they wish in their Jeep. Me personally, I'll stick with 10W-30 which is the preferred oil and has served me rather well.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #13 of 20 Old 09-22-2017, 12:36 AM
Jerry Bransford
Administrator
You keep missing a basic fact.. 5W-30 will never be a 5 viscosity in warmer temps. We'll just have to agree to disagree.
zipman35 likes this.
post #14 of 20 Old 09-22-2017, 01:30 AM
mukluk
5W-30 doesn't match the viscosity of 10W-30 until it reaches 212F... not really sure why it seems so far fetched that an engine would need a minimum viscosity when cold to ensure proper lubrication, even if that "cold" temperature is an ambient of well above freezing.
Maybe I'll understand some day, in the mean time I appreciate the discussion.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #15 of 20 Old 09-22-2017, 07:08 AM
Ironhead
I think this is a better way to look at it.
i'd like to see the viscosity curve between 5w-30 and 10w-30 at different engine temps as neither are 30 until 212 deg. im guessing its minimal and warm up times are under 5 min for me, even when its 20 below
Jerry Bransford likes this.
Ironhead is online now
