99 TJ leaking power steering fluid - JeepForum.com
post #1 of 5 Old 07-01-2010, 03:26 PM Thread Starter
hijumper29
My 99 TJ leaks power steering fluid constantly. Is there a quick-fix that anyone knows of, or do I need to replace the power steering box?
99TJ Sport, 5-speed manual on 33x12.5 BFG MT's with a 4" lift, 4.56 gears
hijumper29 is offline
post #2 of 5 Old 07-01-2010, 03:55 PM
PeteYJTJ
Uh, not to be an arse, but it kinda depends on what's leaking, dude. Is it coming from the box? Pump? A rusted line?
That said, the steering box is a common leaking point. I just replaced my 99 box about a month ago.
Good luck
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #3 of 5 Old 07-01-2010, 04:06 PM Thread Starter
hijumper29
I'm not sure if it's leaking from the box, from the pump or from a rusted line...but i know that power steering fluid leaks are common in TJ's. any tips for identifying the exact source of the leak?
post #4 of 5 Old 07-01-2010, 04:30 PM
PeteYJTJ
Well, for me it was the box. The pump was dry, the lines looked dry, but the box was wet, and it dripped fluid off the pitman arm. I put new lines on anyway - they are only like $20 each.
Check the pump first. Check underneath the pump, feel under it. Check for oil on the pulley and belt. If those are wet, it could be your pump front seal. If the pump is dry, check the lines. Then if all that is dry, it would be the box I would guess.
How many miles on your Jeep? I've got 175K, and my pump was still dry. So, based on my highly technical analysis of 1 Jeep, I think the box leaks before the pump does.
Pete
PeteYJTJ is offline
post #5 of 5 Old 07-01-2010, 04:59 PM
bige2533
My experience has been with a leaking pump. I followed the drip on the ground up to the pitman arm and then up along the lines that went into the box so I knew it was the pump or hoses. I found fluid all over the reservoir and pump so I replaced the pump. Find a good new/used Chrysler pump or go aftermarket. I wouldn't suggest going with a remanufactured unit from the parts stores. There's a great writeup on stu-offroad.com explaining the whole thing.
bige2533 is offline
power steering box , leak , leaking , fix , repair , replace , tj , wrangler
Leaking power steering fluid. Knox TJ Wrangler Technical Forum 5 06-21-2010 04:06 PM
Leaking power steering fluid BChamberlin TJ Wrangler Technical Forum 38 05-27-2009 05:32 PM
Power steering fluid leaking. Pressure switch? ROLNOVR TJ Wrangler Technical Forum 3 04-13-2009 01:03 PM
leaking power steering fluid- NEED HELP! Timmybung TJ Wrangler Technical Forum 6 11-06-2006 08:32 PM
Leaking Power Steering Fluid mtigg21 TJ Wrangler Technical Forum 1 08-13-2005 02:25 PM
