99 TJ - fast idle with AC on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 99 TJ - fast idle with AC on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-29-2014, 01:50 PM   #1
gntl2000
I have 99 TJ Sport (4.0) with AC. I live in Florida so it's toasty right now. When I first start the engine, it idles and drives fine and continues to do so for about 10 minutes with the AC on. After a while, she'll start idling about 1300 RPM at a light with the AC on. If I turn the AC off, the idle will come down to about 800. It's just strange because sometimes if I leave the AC on, have it in first and start letting out the clutch like I was going to stall it - it will nearly stall. I push the clutch back in and it then might idle fine again for a while. I have fully cleaned the TB and IAC by removing them and really cleaning them out. I normally do this as routine maintenance. I'm thinking vacuum leak but I'm not sure. Any thoughts on where next to look?
gntl2000 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 03:13 PM   #2
JWebber
Vac leak or throttle position sensor acting up. I had same problem replaced the TPS. When A/C is running the idle does go up a bit to comp for engine load etc..
But should not go that high.
JWebber is offline   Reply With Quote Quick reply to this message
Unread 08-29-2014, 02:05 PM   #3
gntl2000
I think I am going to try swapping out the TPS. I have checked extensively for vacuum leaks and didn't find any. I cleaned out the TB and IAC. I removed the IAC and completely cleaned it. She ran fine for about a week or two and now the intermittent fast idle is back. Should I go with MOPAR original TPS or is one from Advanced Auto Parts fine? What do you think?
Unread 08-29-2014, 03:15 PM   #4
JWebber
Mopar TPS. Also check the throttle body butterfly and see if it sticks or does not fully close. I used the wrong type of spray fluid once and it dried out my spindle bearings on the throttle body housing. So I bought the right stuff which is for throttle body cleaning and lube. FYI.
