99 tj custom rear upper control arm mounts? - JeepForum.com
post #1 of 7 Old 05-26-2008, 06:57 PM Thread Starter
Neurosis
I have a friend that just ripped off his upper rear control arm mount. He was going to buy new ones and weld them on but has decided to try and fab his own. Does anyone know of a write up for this or have any suggestions that may help him out?
Neurosis is offline
post #2 of 7 Old 05-26-2008, 07:19 PM
raskull
raskull's Avatar
If he still has the old mount you could simply copy it. As long as you keep the actual mounting position the same, the design of the mount itself won't matter so much. Just make sure it's beefy and is welded properly.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #3 of 7 Old 05-26-2008, 07:50 PM Thread Starter
Neurosis
Ive been trying to find a kit that he could copy but havent had much luck. Im sure there are kits around since this seems to be a fairly common problem with the TJ's.
Neurosis is offline
post #4 of 7 Old 05-26-2008, 08:39 PM
aussie stu
polyperformace do a replacement bracket and its well worth the dollars...well for me cause i cant weld.
http://www.polyperformance.com/shop/...cat=158&page=1
Black 98 TJ / 4.5" Coils / 1" BL + MML / 4.56 / 35's Silverstones MT-117 on 16 X 8's / D44 & ARB Airlocker / D30 & lockright / Rocklights / wind sheild IPF's / Custom WARN rear tyre carrier / extended brake lines / Custom Triangulated 4 link long arm / Front adj. panard (no rear) / rear storage draw system / OBA / AA SYE / Bestop duster, windjammer, bikini combo / Bushwackers flares / UHF / TBS / Wilderness Rack / 3" stainless steel snorkel / T-Max 9000 6HP winch
aussie stu is offline
post #5 of 7 Old 05-26-2008, 08:47 PM
otisdog
2008 WK
Frame or axle mounts?
Jim
08 Grand Cherokee Overland
otisdog is offline
post #6 of 7 Old 05-26-2008, 10:20 PM Thread Starter
Neurosis
The weak cheesy frame mounts. I havent seen them myself but im guessing that they failed where most do.
Neurosis is offline
post #7 of 7 Old 04-30-2012, 11:49 AM
ShizfunK
I had both break on my 98 TJ (Left/ Right). I work in a metal fab shop and am looking for the specs on both the frame and axel mounts. Specs on one side of each a piece would be ideal as I can mirror. Also I will be cutting in waterjet so accuracy is a plus. Would need agles and measurments, mine are toast. Thanks for the help.
ShizfunK is offline
Currie Upper Control Arm Mounts alextremetj TJ Wrangler Technical Forum 2 09-21-2009 08:56 PM
Rear upper control arm axle mounts wallowed out!? freshlikefruit TJ Wrangler Technical Forum 10 07-16-2009 09:07 AM
Broken upper control arm mounts. 98TJ38S TJ Wrangler Technical Forum 14 02-02-2009 05:34 PM
Upper Control Arm Frame Mounts Savvy TJ Wrangler Technical Forum 3 01-23-2008 05:15 PM
