99 tj ax5 getting hot - JeepForum.com
post #1 of 9 Old 08-28-2013, 12:44 PM Thread Starter
poisonberry
Anyone heard of a 5 speed manual getting hot on the highway? I took the shift boot off and it feels like a furnace coming from the trans.
poisonberry is offline
post #2 of 9 Old 08-28-2013, 12:48 PM
Zombi
Yep, mine does but that's because it's running on about 1/2 cup of oil.
Check your fluid.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #3 of 9 Old 08-28-2013, 12:51 PM Thread Starter
poisonberry
The first thing I did was change the fluid. The old fluid looked like chocolate milk, kinda like engine oil mixed w/ coolant.
post #4 of 9 Old 08-28-2013, 12:55 PM
2jhanna
And I would change it again. 10/30 motor oil is now approved for the ax5 trannys.
jhanna
denton county, tx
2jhanna is offline
post #5 of 9 Old 08-28-2013, 12:58 PM
Zombi
I mean, that trans is going to be hot to the touch any way you slice it.
Is it making noise?
Difficult to shift?
Feel resistance while coasting?
Call me Z
Zombi is offline
post #6 of 9 Old 08-28-2013, 01:03 PM Thread Starter
poisonberry
Z
None of the above, actually seems to be shifting smoother than normal. Hard to believe. No noise. 20 years being an engine and suspension tech and never noticed a manual getting this hot. Maybe it has always been this hot and I'm just now being picky.
post #7 of 9 Old 08-28-2013, 01:06 PM
Zombi
imo, if it's not causing problems, it's nothing to worry about.
The trans will usually tell you that it's unhappy in other ways than heat buildup.
Call me Z
Zombi is offline
post #8 of 9 Old 08-28-2013, 01:08 PM Thread Starter
poisonberry
True, thanks
post #9 of 9 Old 08-28-2013, 08:18 PM
rcherb
Nothing wrong with it, anytime i popped that cover off on mine it always puts off heat.
rcherb is offline
ax5 , over heat , transmission
