99 TJ 4cyl auto will not start - JeepForum.com
post #1 of 6 Old 07-06-2011, 04:33 PM Thread Starter
robob280
Here's the deal... engine stalled as I was driving and when I restarted the jeep had a loud clicking noise that sped up when I accelerated. Drove it and then parked it, drove it again and stalled a quarter mile later and couldn't restart it.
Pulled the timing chain cover off and there was a plastic guide that was in two pieces. Belt was loose so it did need replacing. Sealed the cover and new belt up, still wouldn't start. From then on replaced distributer, rotor, plugs, wires, and camshaft position sensor. Gets the exhaust to pop a little more and still no start.
Compression is fine, signs pointed to the crankshaft position sensor, when I pulled the old one it had a round disc of metal stuck to it, any ideas on that piece of metal? When I put the new senor in, it would still not start. Both my dad and I are stumped. We can't see anything that it could be in the FSM either. Any help or similar situation help would be great, let me know if you want any more info to help determine the issue.
Rob
robob280 is offline
post #2 of 6 Old 07-06-2011, 07:57 PM Thread Starter
robob280
Help please!!!!! Totally clueless!
robob280 is offline
post #3 of 6 Old 07-07-2011, 07:35 AM
geiman
How loose was your timing chain? Is is possible that it jumped a tooth and now your timing is off? I kind of doubt it, but who knows...
geiman is offline
post #4 of 6 Old 07-07-2011, 08:10 AM Thread Starter
robob280
Well we had guessed it jumped time, but we believe the timing is ok now that we've replaced the chain. We are trying to determine what the small round almost dime size piece of metal was that was attatched to the cks
robob280 is offline
post #5 of 6 Old 07-08-2011, 12:02 PM
g4x4xgeoff
bump for a very confusing situation we're encountering
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #6 of 6 Old 07-08-2011, 12:15 PM
bigred33
Getting spark? Ignition coil?
bigred33 is offline
crankshaft , start problems , won't start
98 TJ with 4cyl/auto dies when put in D TellicoTJ TJ Wrangler Technical Forum 6 09-13-2010 11:02 PM
4cyl Tj with auto? mudslinger97117 TJ Wrangler Technical Forum 12 08-02-2009 09:32 AM
Which auto trans in a 98 4cyl? glennv TJ Wrangler Technical Forum 1 12-17-2006 11:03 AM
3.07 to 4.10 from a 4cyl auto. stevelentz TJ Wrangler Technical Forum 3 02-21-2005 02:45 PM
what tire w/4cyl/auto dbzjeep TJ Wrangler Technical Forum 4 07-29-2003 11:40 PM
