99 Manual Transmission Help - JeepForum.com
post #1 of 9 Old 12-11-2007, 10:42 AM Thread Starter
lilngineer
2007 WK
Hi,
I have a 99 TJ with the 2.5L and 5-speed manual trans. I have noticed that it is randomly difficult to shift into first and reverse gears. All the others are OK.
Also, I have noticed that when it is in reverse, I get a lot of gear whine (fairly loud).
Are these conditions normal or should I suspect some problems?
Thanks,
Jason
lilngineer is offline
post #2 of 9 Old 12-11-2007, 10:50 AM
ryobi
I have precisely the same symptoms in my 98 TJ. I, too, await opinions.
ryobi is offline
post #3 of 9 Old 12-11-2007, 11:11 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Sounds like the gear synchro's (synchronizers)are getting bad to me.Mine has done that for 2 years and hasn't got any worse.You can try some Royal Purple Synchromax or Redline MT-90.It helped mine somewhat.
TheBoogieman is offline
post #4 of 9 Old 12-11-2007, 11:30 AM
ryobi
Which fluid is appropriate for a 98 TJ with 5 speed/4.0 engine?
ryobi is offline
post #5 of 9 Old 12-11-2007, 12:29 PM
TheBoogieman
75/90W gear lube.I switched to the synthetic Redline MT-90.
post #6 of 9 Old 12-11-2007, 03:02 PM
daveg13
daveg13's Avatar
A GL4 gear lube. One of the few available is Redline MT-90 or MTL.
daveg13 is offline
post #7 of 9 Old 12-11-2007, 03:04 PM
creaky70
My '99 TJ has done the same thing from day one. Never got better or worse.
creaky70 is offline
post #8 of 9 Old 12-11-2007, 03:05 PM
Jackle
the reverse whine is normal for all manual transmission vehicles....this is because all forward gears are helical cut gears and reverse is a straight cut gear...don't worry about the whine...its fine
Jackle is offline
post #9 of 9 Old 12-11-2007, 03:49 PM
marc1kim
Ax-5/ax-15 Use the above GL-4.
Pennzoil Synchromesh, or Royal Purple Synchromax is for the newer Jeeps with NV transmissions. Stay away from GL-5 or equivalent gear oils, they aren't freindly with internal brass parts.
One thing to note, Chrysler has superceded their AX-5/AX-15 fluid with Chrysler 10W30 motor oil. Which is pretty much the same viscosity as the GL-3 oil that was originally recommended by Jeep.
and. The Trans Lube chart on the Royal Purple website recommend 10W40 for all 98 and newer manual Jeep transmissions (except for the NV series)
05 LJ
08 JKU Rubicon
marc1kim is offline
jk manual transmission munky_3434 JK Wrangler Technical Forum 32 02-24-2010 06:21 PM
Since I am new to the whole Manual transmission... Yellow09Jeep JK Wrangler Technical Forum 12 12-23-2009 08:47 AM
JK Manual Transmission always JK Wrangler Technical Forum 4 11-09-2006 02:30 PM
Which Manual transmission? domano 68 TJ Wrangler Technical Forum 15 05-15-2006 08:55 PM
New Manual Transmission SpitNine TJ Wrangler Technical Forum 3 04-15-2004 11:11 AM
