99 manual transmission gear oil - JeepForum.com
post #1 of 17 Old 02-12-2007, 09:39 AM Thread Starter
blueknight44
The owners manual calls for 75w-90 api-gl5 gear oil for a manual trans
The rear end calls for 80w-90 gear oil
can 80w-90 gear oil be used in the manual trans without problems?
tia
This's my first Manual trans
blueknight44 is offline
post #2 of 17 Old 02-12-2007, 09:42 AM
SecondTJ
SecondTJ's Avatar
80w90 can be used without issue.
It just depends on GL3/4, GL5
Do you have the AX-5 or AX-15?
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 17 Old 02-12-2007, 10:31 AM
1BadJeepX06
80w90 is fine. That is really a universaly application when it comes to differentials and manual trannies..
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #4 of 17 Old 02-12-2007, 10:57 AM
99TJMark
A '99 with 5 speed manual should have the AX-15. Use NO GL5 lubricants in it. The GL-5 additives eat up yellow metals which is what your synchros are made of. If you have an AX-15 you should be using Redline MTL or MT-90 which are GL 3 and GL4 compatible. Daimler Chrysler printed the owners manual in error when it said GL5 was used in the AX-15.
99TJMark is offline
post #5 of 17 Old 02-12-2007, 12:14 PM Thread Starter
blueknight44
Hi Mark,
I'm AL, you saved the day!
You're 100% correct that the owners manual is incorrect.
I have a tech support company I called to ask for a review of my vehicle's manual.
Here's what they said.
1999 2.5L w 5 speed manual trans has a AX-5 trans that uses GL-3, 75W-90
with the drain plug at the bottom center of the trans, or 6 o'clock low.
The drain plug is a 24MM.
Also the GL-3 is a dealer part or redline gear oil that you use is compatable.
The AX-5 was for the 2.5L engine.
The AX-15 was for the 4.0L engine.
Thanks for the information that will help other 1999 TJ 2.5L AX-5 trans owners.
post #6 of 17 Old 02-12-2007, 12:55 PM
SecondTJ
SecondTJ's Avatar
That depends on what engine is in it.
SecondTJ is offline
post #7 of 17 Old 02-12-2007, 01:35 PM
99TJMark
I made a guess on the AX-15 because he has no info in his profile or in his sig. Either way AX-5 or AX-15 they are both Jap transmissions and both are sensitive to the GL-5 additives. As a matter of fact I checked the '99 FSM and the oil requirements are the same for both.
From the '99 FSM
Recommended lubricant for AX5 transmissions is
Mopar 75W90, API Grade GL3 gear lubricant, or
equivalent.
Correct lubricant level is from the bottom edge, to
no more than 6 mm (1/4 in.) below the bottom edge of
the fill plug hole.
Recommended lubricant for AX15 transmissions is
equivalent.
the fill plug hole.
99TJMark is offline
post #8 of 17 Old 02-12-2007, 01:57 PM Thread Starter
blueknight44
Thanks to all for your replies,
The eye catching comment made about the AX-5 man trans is that it's a "light duty" trans.
I would say my 2.5L engine, with a AX-5 5 speed manual trans shouldn't be called upon to keep up the big boys on some advanced rated trails.
Where can I buy 75W-90 gl-3 gear oil other than the dealer?
I'll update my profile soon.
Tia, AL
post #9 of 17 Old 02-12-2007, 02:00 PM
daveg13
daveg13's Avatar
I get my Redline here: www.myoilshop.com and I believe summit also carries it.
daveg13 is offline
post #10 of 17 Old 02-12-2007, 07:04 PM
James04TJ
James04TJ's Avatar
GL-4 is fine... Redline MT-90 and AMSOIL MTG are commonly available. Motul and Torco also make good GL-4 tranny gear oils but are much harder to find unless you have a GOOD import tuner in your area.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #11 of 17 Old 02-12-2007, 10:14 PM
Kiwi_TJ
AX-5 or AX-15 ?
Hi There,
I too am looking at replacing my manual transmission fluid. Is there any way to tell which transmission I have. Do they look different, or have a code tag anywhere?
I have a 1997 TJ Sport with the 4.0 Engine.
Bye for now,
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #12 of 17 Old 02-12-2007, 10:16 PM
SecondTJ
SecondTJ's Avatar
You have the AX-15
SecondTJ is offline
post #13 of 17 Old 02-13-2007, 08:05 PM Thread Starter
blueknight44
Dealer said 10w-30 replaces 75w-90
My parts house called a local Jeep dealer to verify the AX-5 gear lube
The Redline MT-90 was the only gear oil my parts house could find to be 75W-90 GL-3 for my AX-5 trans.
My parts house had a Jeep dealer fax them that 10w-30 motor oil is recommended to replace 75w-90 gear oil for the AX-5 Jeep trans.
I have the fax with the dealer parts numbers.
How can anyone believe a 10w- 30 motor oil can replace
a 75w- 90 to lube the AX-5 trans?
So if anyone believes this, 10w-30 should be used in differentials
post #14 of 17 Old 02-13-2007, 10:07 PM
SecondTJ
SecondTJ's Avatar
75w90 gear oil is similar to a 10w40 motor oil in weight.
but, they don't have the same properties and additives.
SecondTJ is offline
post #15 of 17 Old 02-13-2007, 10:58 PM Thread Starter
blueknight44
Thanks for your knowledge, I deserve the empty feeling I now have, I just didn't think that 10w-40 motor oil could be like 75w-90.
I was just trying to understand what I was using in my vehicle, and I got buried in a industry of options way over my head.
I should've found Reline MT-90, bought it,installed it, and shut up.
Well now I have knowledge of manual trans oil.
Now I understand I have a light duty manual trans AX-5, that if I stay with stock equipment, tires and don't beat it I should continue owning a fun trail Jeep.
Thanks to all who answered this thread.
Since I am new to the whole Manual transmission... Yellow09Jeep JK Wrangler Technical Forum 12 12-23-2009 08:47 AM
Manual transmission sticks in third gear walter_nicholes TJ Wrangler Technical Forum 2 07-16-2008 11:23 AM
Manual transmission gear ratios Hook67 JK Wrangler Technical Forum 4 04-24-2008 08:15 AM
99 Manual Transmission Help lilngineer TJ Wrangler Technical Forum 8 12-11-2007 03:49 PM
Which Manual transmission? domano 68 TJ Wrangler Technical Forum 15 05-15-2006 08:55 PM
