99' Jeep Wrangler starting issue - JeepForum.com
post #1 of 2 Old 05-27-2008, 02:04 PM Thread Starter
Bandit84
Hey everyone, i have a 1999 Jeep that my parents bought new. Its the Sahara edition, 4.0l, auto, 125k. When you go to start it, whether its hot or cold, it wont fire on the first try, always the second. If you turn the key on, then off and on again, it starts great. So what are some things this could be. It seems like the fuel pressure doesnt build up.
Any help apreciatted thanks.
85' CJ7
Bandit84 is offline
post #2 of 2 Old 05-27-2008, 09:34 PM
little4x4
There is a check valve in the sending unit (in tank) that is supost to hold fuel in the lines and fuel rail, when it goes out the fuel drains back and it takes one or more cycle of the key to reprime before it will start. Only cure is to replace the unit in the tank as far as I know.
00 tj Old man emu susp. 1" bl 285x75 Procomp Xterrain's warn x8000i in an ARB fnt bumper custom rear with tire carrier, high lift jack locked in fnt and LSD in the rear, sway bar disconnect, steering engine and fuel tank skids, 4L engine, 5 speed tranny, 4.10s and a few other things.
little4x4 is offline
Jeep Wrangler Hard Starting jerrytruchan TJ Wrangler Technical Forum 24 12-14-2014 05:44 PM
Jeep Gurus Help with starting issue GenoSport TJ Wrangler Technical Forum 7 12-26-2007 02:23 PM
hard starting 1999 jeep wrangler tom black TJ Wrangler Technical Forum 6 10-09-2007 09:13 AM
Jeep Wrangler Starting Issue Jeep97Wrangler TJ Wrangler Technical Forum 9 06-09-2007 05:30 PM
Problems Starting my Jeep Wrangler DMBwezz03jeep TJ Wrangler Technical Forum 1 04-24-2006 08:12 PM
