Quantcast 98 Wrangler :All the sudden extremely hard to shift and rear grinds - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 98 Wrangler :All the sudden extremely hard to shift and rear grinds
Old 03-01-2005, 10:48 AM   #1
Zodiacboyscorp
98 Wrangler Manual:All the sudden extremely hard to shift and rear grinds
I've had no problems to give me any warning.
I have a 1998 Jeep Wranger 4 cylinder manual trans.
This is what happens. I was going to work like normal. I went into reverse just fine. Driving was flawless. All the sudden while driving it has become extremely hard to shift. I have to force the sucker. Reverse only grinds however once you get it in its fine.
I have tried to turn of the vehicle put it in reverse and start it. Works find then it's hard to shift. No other gear makes grinding noises, when shifting into, they just are extremely hard.
No signs of any problems before this.
Don't worry I haven't been driving it was just testing. Wanted opinions.
Zodiacboyscorp is offline   Reply With Quote
Old 03-01-2005, 11:56 AM   #2
Zodiacboyscorp
Is this in the right section?
Old 03-01-2005, 12:48 PM   #3
MarkF
Manual or Auto?
98 Gunmetal Sport - RE 4.5 LA, BFG 35", 1" BL/MM, D44 & lots of armor.
MarkF is offline   Reply With Quote
Old 03-01-2005, 12:50 PM   #4
MarkF
If it is a manual the clutch slave cylinder can cause those symptoms. Did you check teh clutch fluid level or look for leaks?
Old 03-01-2005, 02:57 PM   #5
Zodiacboyscorp
It is a manual transmission.
The fluid level seems to be decent. There doesn't seem to be any leaks.
Old 03-01-2005, 03:03 PM   #6
MarkF
I still say clutch slave cylinder. Hopefully some one else will chime in.
Old 03-01-2005, 03:04 PM   #7
JeepKidd
i think it only grinds when the jeep is rolling forwards (when shifting into reverse). It does it to me.
[B][COLOR=Navy]Hurricane Jeep Club Member # 4[/COLOR]
[COLOR=DarkRed]Under 18 Jeep Club Member # 5[/COLOR]
[COLOR=DarkGreen]Green Jeep Club Member # 127[/COLOR][/B]
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Hella 500 Driving Lighs
2 Delta Fog Lights
JeepKidd is offline   Reply With Quote
Old 03-01-2005, 03:06 PM   #8
MarkF
This sounds like the syncros and would be normal.
What is described by Zodiac is not this.
Old 03-01-2005, 03:11 PM   #9
Zodiacboyscorp
No it grinds when stopped and everything else is hard to shift into. Extremely hard.
I just can't figure it out, it went from perfect to worse than worse!
BTW thanks mark!
Still haven't figured it out.
Old 03-03-2005, 08:26 AM   #10
Zodiacboyscorp
BUMP!
I have a friend who is going to look at it today. Any more tips would be appreciated.
My guesses right now are
Slave Cylinder
and water in the fluid...(The ex put water in the gas tank before this problem...so I'm wondering)
Old 03-03-2005, 08:50 AM   #11
MR.CLIFFORD
MR.CLIFFORD is offline   Reply With Quote
Old 03-03-2005, 09:08 AM   #12
MarkF
BUMP!
Slave Cylinder
Time to buy a hood lock
Old 03-04-2005, 07:46 AM   #13
SteveBad
2011 JK Wrangler
It's grinding and stiff because the clutch isn't completely disengaging.
Some of the causes could be a low clutch fluid level, or air in the line,
or on older cars, a bent throwout bearing fork.
SteveBad is offline   Reply With Quote
Old 03-04-2005, 11:13 AM   #14
JFM626
Senior(not yet 65)Member
I think it is safe to asume that you have checked the transmission fluid for correct level, I remember on an older Landcruiser that after a few weeks of leaking a little every day that it became almost impossible to shift. You can check the slave cylinder, by having a friend step on the clutch, while you look at the slave cylinder to see if its moving the push rod. Make sure you have the park brake on, engine off. The water in the clutch fluid is certainally a possibility, especially if it is cold where you are, it could actually be turning to ice. It is also possible that you have lost the facings from your clutch disc, however when that happens you usually don't move. If I remember correctly your transmission does not have a syncro in reverse, and before this happened you had to wait a few seconds before you could shift into reverse, and the jeep had to be stopped. The fact that it only grinds now certainly indicates a clutch related problem. Good luck.
JFM626 is offline   Reply With Quote
Old 03-04-2005, 12:53 PM   #15
Texan4life
You have me sold on hood locks. I would change all of my fluids and stay away from women for a while.
I had problems with a Ford Ranger 10 years ago. With the engine off, does it shift smoothly? Yes-look at the clutch. No-look at the transmission. At least that is what I have heard. Good luck.
Amendment 10 -
The powers not delegated to the United States by the Constitution, nor prohibited by it to the States, are reserved to the States respectively, or to the people.
Texan4life is offline   Reply With Quote
Glock Forum
