98 Tj surging when cold - JeepForum.com
post #1 of 9 Old 08-05-2010, 05:37 AM Thread Starter
Odiwh
Hey guys I have a 98 Tj 4.0 with an automatic transmission. About a month ago it starting surging while I drive when the vehicle is cold. I will have the pedal pressed and rpm's at about 3000 and it will suddenly drop to 1000 then pick back up and drop again. It does this for about 15-20 seconds then usually stops. It also will stall at a stop light or stop sign every so often. Once warmed up it seems to run fine. I have replaced plugs,cap,wires,router, IAC and throttle body position sensor and it's still doing it. Does anyone have any idea what this could be? Has anyone seen this before?
Odiwh is offline
post #2 of 9 Old 08-05-2010, 07:32 AM Thread Starter
Odiwh
Also, when the rpm's fluxuate there is a clicking noise coming from the front axle is sounds like, not sure if this is related to the problem
Odiwh is offline
post #3 of 9 Old 08-05-2010, 03:00 PM Thread Starter
Odiwh
Bump
Odiwh is offline
post #4 of 9 Old 08-05-2010, 03:23 PM
AlphaTJ
Check the upstream O2 sensor.
http://www.jeepforum.com/forum/f9/cu...bad-o2-723569/
Also for good measure, clean the battery posts and terminals. That corrosion created some weird gremlins with my 98.
AlphaTJ is offline
post #5 of 9 Old 08-05-2010, 05:12 PM
SnatchBlock
Just had the exact same symtoms from my 99tj. Replaced the up stream o2 sensor and it is fine now.
SnatchBlock is offline
post #6 of 9 Old 08-06-2010, 05:35 AM Thread Starter
Odiwh
The thread Alphatj directed me 2, the guy said he notices it's worse after the jeeps warm and he has to restart it. Once my tj warms up I never have a problem till it sits and gets cold again. Also it kinda feels like a misfire or it's have trouble getting fuel. I will try upstream o2 sensor though.
Odiwh is offline
post #7 of 9 Old 08-06-2010, 11:56 AM
AlphaTJ
I included that link because Jonny Jeep gives a way to check the sensor, didn't clarify that in the original post. If you have replaced all of that other stuff, it could be worth checking out.
AlphaTJ is offline
post #8 of 9 Old 11-10-2012, 03:26 PM
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
Did you replace your upstream o2?
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #9 of 9 Old 11-11-2012, 09:08 AM
Halverson
Might seem obvious but check the tranny fluid. Lurching when cold happens on my TJ when its low.
Halverson is offline
tj , wrangler , sputtering , rough idle , surging
Cold, cold, cold air blowing when the heat is on fstfl YJ Wrangler Technical Forum 9 12-02-2010 12:08 PM
surging idle and surging throttle on warmed freshly turned on engine ChaosMTB TJ Wrangler Technical Forum 2 04-08-2008 08:21 AM
02 wrangler hesitating/surging on cold starts ghost4545 TJ Wrangler Technical Forum 10 03-13-2008 12:25 PM
WTF Surging!? AustinJeep TJ Wrangler Technical Forum 14 11-06-2006 08:34 PM
4.2 surging when cold at idle fsfsa1 YJ Wrangler Technical Forum 0 12-31-2004 09:29 PM
