Quantcast 98 Tj Right Side Suspension Lean - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 98 Tj Right Side Suspension Lean
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 11-03-2009, 01:47 PM   #1
thumpergtivw
I have a strange 1 inch height difference from left to right side and not quite sure when and/or how this came about.I have a 98 sahara tj that 6 months ago WAS stock. First thing i did was installed a 3 inch urethane spacer lift from fat bobs garage that comes with pro comp shocks. running 31's. Secondly, i installed a 1.25" body lift with urethane blocks, and a transfer case drop. Running pro comp 35x12.50r15 mud terrains. Now, I already checked the body lift from one side to the other and no difference. Now this week i installed rough country 4 inch lift springs and all 4 lower x flex adjustable control arms and rear track bar. I thought the springs in the rear was the problem since there is a service bulletin out on r rear spring sag in which rough countrys rear springs are 2 different thicknesses and heights to correct the problem, BUUUUT ! STILL LEANIN. PS, my coworkers teraflex 4 inch lifted 97 does the same thing.
thumpergtivw is offline   Reply With Quote
Old 11-03-2009, 03:27 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
That's pretty common, engine torque shifts weight towards the passenger-side springs and the rear spring takes the majority of it. My R-R spring has sagged nearly an inch from this issue.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 11-03-2009, 04:11 PM   #3
cmc1
jerry when you have to lift the rear for other work do you think it would be a good idea to switch the rear springs from side to side every once in a while?
cmc1 is offline   Reply With Quote
Old 11-03-2009, 08:01 PM   #4
Jerry Bransford
It couldn't hurt if you're bored & have nothing better to do.
Getting Savvy...
Old 11-04-2009, 08:31 AM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I think the rear track bar has a lot to do with it.
My TJ used to lean to the passenger side slightly, but after installing a 4-link kit in the rear, it sits perfectly level.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 11-04-2009, 06:48 PM   #6
little4x4
2x on the track bar.. my OME 2.5 lift came with the common relocation bracket this is what caused mine to sag do to to much pull. I removed the dang thing and got an adjustable track bar and once I realigned it all was good and no sag now.
00 tj Old man emu susp. 1" bl 285x75 Procomp Xterrain's warn x8000i in an ARB fnt bumper custom rear with tire carrier, high lift jack locked in fnt and LSD in the rear, sway bar disconnect, steering engine and fuel tank skids, 4L engine, 5 speed tranny, 4.10s and a few other things.
little4x4 is offline   Reply With Quote
Glock Forum
