98 TJ Hell-Sputter *tried many things - JeepForum.com
post #1 of 9 Old 02-21-2012, 07:24 PM Thread Starter
WranglerLZ
Hey guys,
I just joined the forum (something i wanted to do for a while) but my current problem has made it more urgent.
Scenario: I have a 98 TJ 4 Cyl Manual. As many people are aware they have a sputtering problem. My specifically started a while ago when I become a little stuck in a river. (no worries fellow jeepers help me out). When it started back up it sputter for about an hour and then was fine. I assumed something was just wet and dried off.
That was about 5 months ago. Never heard it again until yesterday. It's not humid out here in Illinois and wasn't raining. It sputter immediately at starting. The sputtering gets worse when it is in gear but is weirdly on and off. Low RPS sputters, around 2000-2500 drives fine, then if you get on the gas it sputters again.
I started with the basic fixes. Started by running some Seafoam through by pouring it in the gas tank to clean the injectors. Then replaced the spark plugs, distributor cap, rotor and all the cables. Then i unplug the o2 sensor on the exhaust before the cat......Still no change. I even pulled the 4th cylinder while running to see if it was getting power and it defiantly is (shocked myself). I took it to autozone and all they were able to tell me was it was defiantly the 4th cylinder misfiring.
Any more ideas why this sputtering stays!?!?! Sorry for the long post but I want to make sure my situation is clear. First one to solve my problem gets a big thumbs up!
WranglerLZ is offline
post #2 of 9 Old 02-21-2012, 08:35 PM
Stu Olson
Stu Olson's Avatar
#4 injector?
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 9 Old 02-21-2012, 08:54 PM
PlaneJob
Conjugate your verbs.
PlaneJob is offline
post #4 of 9 Old 02-23-2012, 10:09 PM Thread Starter
WranglerLZ
Hey sorry bout the verb-age but i replaced the forth injector and it wasn't it. Any other ideas?
post #5 of 9 Old 02-23-2012, 10:49 PM
JPNinPA
Did you check your distributor cap, rotor and as above your timing/distributor?
Just cause you got shocked does not mean the plug is good and firing correctly.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #6 of 9 Old 02-27-2012, 02:30 PM Thread Starter
WranglerLZ
Il check that. Someone suggested that the seafoam possibly cleaned the gas tank and cause all the debris in there to clog fuel filter?
post #7 of 9 Old 02-27-2012, 02:51 PM
Dice48
THen you would be having a problem on all cylinders not just four. Try spraying the plug wires with soapy water. Could be a rip in the insulation.
KCCO
Dice48 is offline
post #8 of 9 Old 02-27-2012, 08:10 PM
JPNinPA
To verify check the fuel pressure. But if it were, it would likely be multiple cylinders as mentioned.
JPNinPA is offline
post #9 of 9 Old 04-04-2012, 12:50 PM Thread Starter
WranglerLZ
Well i broke down and took it in before i spent any more money. Appartently i put in some sub-par spark plugs and actually fried one within the first day! They replaced the plugs again and now it runs fine
sputtering , sputters , tj
YJ Sputter fixnstuf3 YJ Wrangler Technical Forum 49 06-21-2011 07:42 AM
Sputter (again)... VERY BAD! BChamberlin TJ Wrangler Technical Forum 7 10-23-2009 02:12 PM
Sputter Sputter Sputter FlexinYJ YJ Wrangler Technical Forum 5 08-09-2009 10:44 AM
Turn Key, Crank, Sputter, Sputter, Run.. JFiorentino TJ Wrangler Technical Forum 3 07-24-2004 10:34 AM
sputter Lyle36 YJ Wrangler Technical Forum 1 04-04-2003 05:46 AM
