98 TJ front wiper motor - JeepForum.com
post #1 of 3 Old 09-01-2009, 07:02 PM Thread Starter
bombero590
My front windshield wiper motor started to make some odd sounds..I guess it will be time soon to replace, and i wanted to know if anyone knew of any good write ups on how to replace it..Thanks again fellow Jeep Forum menbers...
bombero590 is offline
post #2 of 3 Old 10-12-2009, 02:03 PM
spunky424
bump i'm also looking for a good write up
spunky424 is offline
post #3 of 3 Old 10-12-2009, 07:00 PM
BlueFlame
BlueFlame's Avatar
Open up the cowl cover and look at it, it's pretty obvious.
Unplug motor, remove nut from shaft and pull off the linkage arm, remove the 3 screws holding the motor in place and lift it out.
Intallation is the reverse.
One tip: To make sure the motor is in "time" I always plug it in before I connect the linkage to it, and turn on the wipers once then turn them off so the motor "parks." Then connect the linkage arm. Avoids any possiblity of the wipers going the wrong way on first startup.
BlueFlame is offline
front wiper motor replacement writeup w/pics vettefever5 TJ Wrangler Technical Forum 52 06-14-2016 01:12 PM
Windshield wiper / wiper motor mms1946 TJ Wrangler Technical Forum 8 11-28-2009 08:25 PM
Front windshield wiper motor bustard TJ Wrangler Technical Forum 3 01-08-2009 08:00 AM
front wiper motor asa TJ Wrangler Technical Forum 1 05-01-2008 10:47 PM
problem with front wiper motor thenewkid TJ Wrangler Technical Forum 4 07-11-2004 01:41 PM
