98 TJ cracked header - JeepForum.com
post #1 of 21 Old 05-23-2006, 11:30 AM Thread Starter
tjaggie
I own a 98 and my header has cracked. Does anyone know if I can JB weld it to get by for a while until I have the cash to buy a new header. The one I want is the Banks header. Is that the best I can get or does anyone else recommend something different. Also how difficult it is to remove and install the new header. Any help would be appreciated.
tjaggie is offline
post #2 of 21 Old 05-23-2006, 11:33 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its not that difficult of a job.
I wouldn't waste your time with the JB Weld. It will not hold up.
Also, I wouldn't recommend a Banks header. They have cracking problems too.
For your best chance at preventing the same problem in the future, go with a replacement header that has expansion joints. Like the one advertised at the top of the page here.
Wheelin98TJ is offline
post #3 of 21 Old 05-23-2006, 01:08 PM
Dogman
Dogman's Avatar
I agree. That's the one I bought. It's been over a year and it's fine.
John 3:17
Dogman is offline
post #4 of 21 Old 05-30-2006, 01:08 PM
eR1c
I just replaced my cracked exhaust manifold on my '97 TJ with a header from pace-setter (it was $200 for the new header).
In my opinion there is no need to spend $500+ on a Borla exhaust. In fact (in my opinion) there is no need to purchase a chrome/polished exhaust for an extra several hundred dollars when the black headers (most companies sell a plain black version) are the same design and function just as good as chrome/polished headers. Also on our jeeps you can't even see the header, it's obstructed from nearly every angle you look at it. -Go for function it will be less $$ than the chrome/polished headers.
Install,
-It took me 6 hours to install my header on my '97 tj. the install would have taken about 4 hours had I been given a few tips (which I'll give to you)!
Here is the install process:
1st photo shows the stock 97 tj engine
eR1c is offline
post #5 of 21 Old 05-30-2006, 01:09 PM
eR1c
I began by removing the air intake tube, disconnecting many of the electrical connections, the fuel injector electrical connections, and loosening the power steering pump from the intake manifold.
eR1c is offline
post #6 of 21 Old 05-30-2006, 01:12 PM
eR1c
I even removed some of the smog emmisions stuff (see in the lower right corner).
The manifold is now ready for me to begin loosening the bolts.
To get to this point took me about 2 hours. (i took my time and went slowly paying attention to where each part i removed goes for when I put them back).
eR1c is offline
post #7 of 21 Old 05-30-2006, 01:14 PM
eR1c
I removed all the intake manifold bolts, the manifold is now free to allow the exhaust manifold to come out. The intake manifold is still connected by some wiring which I did not feel comfortable removing... but it was free enough that I could move it enough to get the exhaust manifold out.
eR1c is offline
post #8 of 21 Old 05-30-2006, 01:16 PM
eR1c
the old manifold is out and laying side by side with the new header. Notice the design differences.
It took me about 4 hours to get to this point.
(one hour was spent trying to figure out how to remove the bolts from the outlet of the stock exhaust manifold. I realized after an hour that the bolt heads were welded at the factory to the stock manifold... (see the bolts on the stock manifold in the picture below). ...all I had to do was loosent the nuts and the stock exhaust was free).
eR1c is offline
post #9 of 21 Old 05-30-2006, 01:17 PM
eR1c
check out that crack!! it went all the way around the exhaust pipe... what a horrible exhaust manifold they gave us!!!
...and the back side
eR1c is offline
post #10 of 21 Old 05-30-2006, 01:22 PM
eR1c
after cleaning the head where the old gasket was (with some light sand paper) I put a new gasket on the head (not shown in this photos) and wiggled the new header into position. This wiggle process took about 45 minutes and would have only taken 15 minutes had I had a partner to hold the intake manifold up while I positioned the new header... however I had to do this alone and balane both parts.. one in each hand!
..after this I tightened all parts (using the correct tightenting sequence per spec) and put all the parts I took off back. Then took for a test drive... it's now very quite and feels like it has more power than w/ the previous exhaust manifold. The total job cost me just under $200 (for the header) and about 6 hours of labor. -If I did this again on a jeep it would take me about 4 hours. (every car/truck has their own set of issues when replacing things, etc..).
anyway, hope this helps. I'd say this is an intermediate level job for someone with a certain amount of comfort and experience fixing/replacing things on their car.
eR1c is offline
post #11 of 21 Old 06-02-2006, 07:15 PM
rusty-rubi
Junior Member
rusty-rubi's Avatar
Borla header Install
Check out my post in this thread "installing borla headers". I give a description of my encounter. I have since put on a V Force muffler and it sounds good a low RPM but at midrange and higher sounds a bit like an import. I think the V Force is about the same as the Flowmaster 40. '98 will be slightly different than a '97.
I have never heard of a successful repair of a header.
rusty-rubi is offline
post #12 of 21 Old 06-02-2006, 07:21 PM
Sandbox
Sandbox's Avatar
I bought the one advertised above as well and put it on last Saturday. It wasn't that bad, it just took a little time. It takes a little more time if you forget to plug the Fuel pump relay back in.
Getting the torque wrench in there did require some creativity for some of the bolts though.
2012 JKU Sport S
2004 WJ 4.7 Limited - SOLD
"DULCE ET DECORUM EST PRO PATRIA MORI"
Sandbox is offline
post #13 of 21 Old 06-02-2006, 08:41 PM
hoosier724
hoosier724's Avatar
left corner of this page
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline
post #14 of 21 Old 06-03-2006, 12:42 AM
joedirt88
Without the expansion joints....that new one youll be putting will be cracking the same way. Spend your money once.
joedirt88 is offline
post #15 of 21 Old 06-03-2006, 02:23 AM
KnightFire
KnightFire's Avatar
Honest Question:
What are these expansion joints you refer to? I've seen a LOT of different types of headers for a ton of different vehicles, I've never heard of the term 'expansion joints' for a header before.
I checked the site that I'm 'assuming' has these 'expansion joints' (upper left hand corner of the forum) and I didn't find that term anywhere on their site. Please advise...
As a side note:
I've had a Borla header on mine for 4 years now, no problems in to date, except the Y-pipe bolts tend to vibrate loose #!$%@#$%...other than that, I have no complaints, next time I'm under there I plan on getting new hardware and using some serviceable thread lock, that should cure that!
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
Header Bow cracked.. MacK JK Wrangler Technical Forum 6 03-22-2010 02:30 AM
my header is cracked 92renegade YJ Wrangler Technical Forum 4 08-17-2009 10:34 AM
cracked header mattman8706 TJ Wrangler Technical Forum 8 09-18-2006 10:08 AM
Cracked Header jisl YJ Wrangler Technical Forum 9 05-16-2003 11:11 AM
Cracked Header 2High4U YJ Wrangler Technical Forum 1 10-25-2001 08:22 PM
