98 Steering Gearbox Leak - JeepForum.com
post #1 of 9 Old 08-28-2010, 06:13 PM Thread Starter
Loganwolf
I have a slight power steering leak around the pitman arm shaft on the gearbox. I bought a replacement seal kit from advance auto parts but I was wondering if this is worth doing? I have read that the 98 durango gearbox is a great upgrade but money is a little tight and the seal kit was only like $9 vs $164 for the new durango with snow plow box. This is not a serious leak but I am the kind of person that if I fix it once I do not want it popping up again anytime soon. So the question I have is if I replace the seal what is the chances of it leaking again soon. Also keep in mind that I have 31s on my Jeep so I am not that far over the factory tire size.
Loganwolf is offline
post #2 of 9 Old 08-28-2010, 06:21 PM
97tjeff
Welcome to the life of a TJ. Everyone's steering gear box leaks. You can do the durango swap, but it's really not that beneficial if you're planning on staying with 31's.
97tjeff is offline
post #3 of 9 Old 08-29-2010, 06:42 PM
BlueFlame
BlueFlame's Avatar
When replacing the seals, be extremely careful not to nick them. Most reseal jobs fail, and (in my opnion) that is why.
BlueFlame is offline
post #4 of 9 Old 08-29-2010, 07:29 PM
J_Mas24
durango box
i upgraded to the durango steering box and absolutely love it....the factory gear box barely leaked on mine with 31s on it and when i upgraded the suspension and tires to 33s it finally gave out....i just always kept a bottle of power steering fluid in my jeep till i saved up for the swap.
J_Mas24 is offline
post #5 of 9 Old 08-29-2010, 07:57 PM
DanaJeepTech
If you can do it yourself, then it is absoultely worth doing. If you are lucky the seal wore out which isn't terribly uncommon. If you aren't as lucky, the pitman shaft has started rusting and that is what tore the seal. Just be sure the shaft is clean and smooth where the seal rides. A little emory cloth should help if it has started corroding.
DanaJeepTech is offline
post #6 of 9 Old 08-29-2010, 08:21 PM
viperbluelx
Lucas Power Steering Fix
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #7 of 9 Old 08-30-2010, 03:11 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by 97tjeff View Post
Everyone's steering gear box leaks. .
Mine didn't. On 35s for 5 years so far.
post #8 of 9 Old 08-30-2010, 03:12 PM
BlueFlame
BlueFlame's Avatar
Worst idea ever.
post #9 of 9 Old 08-31-2010, 09:23 AM Thread Starter
Loganwolf
Ok thanks everyone. I don't think I am going to really worry about it because it has been leaking for a few months now but I have yet to have to add power steering fluid in the system. It is a really slow leak that or something else is leaking near the steering box. I am planning on replacing the steering box at some point with the durango box because at some point I want to put bigger tires on the jeep.
Steering gearbox help Dewster196 YJ Wrangler Technical Forum 4 07-23-2009 07:47 AM
Steering Gearbox Parts doughnutdog YJ Wrangler Technical Forum 4 07-18-2009 06:22 PM
gearbox leak raven4640 TJ Wrangler Technical Forum 8 11-04-2007 04:49 AM
steering gearbox swap Texas TJ TJ Wrangler Technical Forum 4 10-18-2006 05:12 PM
Power Steering Gearbox davidc2000 TJ Wrangler Technical Forum 4 08-03-2004 07:52 AM
