98 rear upper passenger shock mount - JeepForum.com
post #1 of 4 Old 12-27-2009, 09:28 PM Thread Starter
PurpleTJ
yes, i searched. most of what i found was for YJ's.
like the title says, my RR upper shock mount got ripped out while wheeling. took the shock out as soon as i found out, and drove 70 miles home on 3 shocks.
what can i do about fixing this? is the only way to drill and tap a new hole? or can i somehow access the top of the mounting location so i could just put a bolt through the hole and thread a nut onto the top side? the shock/barpin are fine.
Purple Jeep Club member #8
PurpleTJ is offline
post #2 of 4 Old 12-28-2009, 09:29 AM Thread Starter
PurpleTJ
bump
10char
PurpleTJ is offline
post #3 of 4 Old 12-28-2009, 09:40 AM
RubiconRazorbac
RubiconRazorbac's Avatar
You can get in there, but it's much easier with a 1.25" body lift. Otherwise you can loosen (not remove) your body mount bolts and lift the body up an inch or so to get to the nuts.
Or, you can do this and not have to worry about it again: http://www.jeepforum.com/forum/f9/ou...cation-929056/
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #4 of 4 Old 12-28-2009, 09:51 AM Thread Starter
PurpleTJ
thanks, ill take a look at it today. outboarding isn't an option quite yet
PurpleTJ is offline
Rear Upper shock mount. Btwngreengray YJ Wrangler Technical Forum 9 05-21-2009 06:03 AM
upper rear shock mount Tj BEANS TJ Wrangler Technical Forum 7 01-07-2006 10:47 AM
Upper Rear Shock mount ? 93YJjeep YJ Wrangler Technical Forum 20 10-13-2005 08:54 PM
Rear upper shock mount 92wrangler YJ Wrangler Technical Forum 14 06-28-2005 11:37 AM
rear upper shock mount help monkeywrench YJ Wrangler Technical Forum 3 03-20-2003 07:28 AM
