98 Problems ONLY in 2nd gear - JeepForum.com
post #1 of 1 Old 04-20-2012, 07:50 PM Thread Starter
dwampler07
I really need some help since I have no idea what the problem could be. When I am shift into 2nd gear my jeep will start bucking/jumping like its having trouble getting fuel but I don't know why this would only be in 2nd gear. I don't have any problems when I get up to higher speeds and I don't have any problems in 1st gear. I have had this happen mostly going up hill but also on flat ground. Any suggestions would help. And also no check engine light. Thanks
dwampler07 is offline
engine help , fuel injector , fuel pump , tj , transmission
87 yj problems getting into gear shawnyj YJ Wrangler Technical Forum 6 05-24-2010 01:54 AM
4th gear problems 03Wrangler TJ Wrangler Technical Forum 0 05-17-2008 09:06 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
4th gear problems FranV TJ Wrangler Technical Forum 2 09-08-2007 10:41 AM
Problems with second gear AggieTJ TJ Wrangler Technical Forum 2 05-17-2004 12:56 PM
