98 grand cherokee dana 44 puting under a 98 wrangler tj - JeepForum.com
post #1 of 3 Old 12-09-2011, 05:35 PM Thread Starter
chadtheman
hello everyone
Wanted to see if anyone has done this or knows what modification i would have to do to the axle.
Here is what i want to do. 98 grand cherokee rear axle is a dana 44 with 3.73 gears, I have a 98 wrangler with a dana 35 with 2.73 gears. I want to put the gear end of the grand cherokee under the wrangler. Does anyone know id this is going to work. I can not find much information on this on the web and havent had much luck.
Has anyone done this?
I havent purchased the axle yet because i dont want to waste my money incase it doesnt work!!!!
Please let me know you advise
Thanks
chadtheman is offline
post #2 of 3 Old 12-09-2011, 05:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The Aluminum Dana 44a under Grand Cherokees is as worthless as a Dana 35 and has fewer options for aftermarket upgrades like lockers. The D44a is easy to bend, and suffers from major problems with premature failure of the carrier bearings.
Are you sure you have 2.73 gears ? There is no info about your Jeep in your posting, or in your JeepForum Profile.
CJ7-Tim is offline
post #3 of 3 Old 12-09-2011, 05:53 PM
MO2500
x2, it's not worth your time to swap in the D44a.
Instagram: @omsmike
MO2500 is offline
grand cherokee dana 35 88wagon TJ Wrangler Technical Forum 8 02-28-2010 10:20 PM
Grand Cherokee dana 44 into a TJ? UTWeezul TJ Wrangler Technical Forum 9 09-25-2006 09:21 AM
Grand Cherokee Dana 44 in a TJ skates04 TJ Wrangler Technical Forum 3 02-17-2005 02:51 PM
wrangler vs. grand cherokee gutpile YJ Wrangler Technical Forum 7 10-22-2002 03:34 AM
Dana 44 out of Grand Cherokee bk_jeepin TJ Wrangler Technical Forum 2 05-03-2002 03:07 PM
