97 wrangler wont start Computer problem?? - Page 2 - JeepForum.com
post #16 of 21 Old 07-26-2010, 06:50 PM Thread Starter
fire1998
An update:
We found that the cam position sensor looks like it was arcing. We'll replace it tomorrow and see if this solves the issue.
fire1998 is offline
post #17 of 21 Old 07-30-2010, 04:47 AM
Ghaniba
So was it the Cam Sensor?
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline
post #18 of 21 Old 07-30-2010, 08:17 AM Thread Starter
fire1998
Nope. The connection thats tells the coil to fire, in the pigtail next to the computer, was loose. We tightened that up and it has been starting great. Took 4 hours to trace it down.
fire1998 is offline
post #19 of 21 Old 01-13-2013, 07:20 PM
NavyGM0718
I realize this is an old post, but mine is doing the same thing. You didnt mention it, but wondering if you remember if your gauges stopped working too? And which Pig tail/ wiring was loose? if you remember?
Thanks
97 wrangler, 4.0L manual
NavyGM0718 is offline
post #20 of 21 Old 04-23-2015, 11:17 PM
dude33
I have a jeep wrangler 2.5 it started shaking Nd funning rough so I did plugscap wire coil and distributor as well as tps map senor crankand cam sensorsshift senor the timing cain water pump intake exhaust gasket new fuel injectors . Nothiced the shift up arrow is on not smoking burning oil or any other fuild. now win I try to start it all lite go off and radio go to reset and it does nothing.. It all started with multiple mis fires took valve cover of no broken . Cylinders all have great presser fuel presser good . If I start it in gear it shakes a low idle . And whats to die coming from high to low idle ???? Im am thunking pcm hell every thing else is new ...
dude33 is offline
post #21 of 21 Old 04-24-2015, 02:29 AM
Jonny Jeep
Jonny Jeep's Avatar
Get the battery charged and tested. Bad batteries can cause rough running and false codes.
Jonny Jeep is offline
no start
91 2.5L wrangler cranks but wont start, fuel problem 91wranleron31mt YJ Wrangler Technical Forum 11 08-20-2012 01:54 PM
Wrangler wont start...sometimes Skullx TJ Wrangler Technical Forum 12 02-23-2011 12:59 PM
88 wrangler wont start 88yj YJ Wrangler Technical Forum 30 04-27-2010 08:22 PM
02 wrangler wont start idnthaveadd TJ Wrangler Technical Forum 2 08-04-2007 11:49 AM
Wrangler problem ... new computer? JeepinJosh TJ Wrangler Technical Forum 3 12-05-2003 07:14 PM
