97 wrangler wont start Computer problem?? - JeepForum.com
post #1 of 21 Old 07-24-2010, 05:15 PM Thread Starter
fire1998
My 97 2.5L Wrangler will not start. There is fuel pressure at the rails. We reset the computer and it started and ran for 2 days. Went to start it this morning and no starty!!! We tightened the grounds, 1 was loose. What can be causing the compoter to shut down?
Thanks
fire1998 is offline
post #2 of 21 Old 07-24-2010, 09:21 PM Thread Starter
fire1998
Anyone ever had this happen? The computer just shuts down.
fire1998 is offline
post #3 of 21 Old 07-24-2010, 09:32 PM
MJMPC
Have you checked for codes?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 21 Old 07-24-2010, 09:35 PM
1jack5
Mine did the same thing, it was the Crankshaft Position Sensor, very common on the 4.0s dont know about the 2.5s. I thought it would through a check engine light but they dont always do.
If thats not it you could always do the old "It takes 3 things for a engine to run fuel, spark, and air" and go from there....
1jack5 is offline
post #5 of 21 Old 07-24-2010, 10:51 PM Thread Starter
fire1998
No codes.......No check engine light!!!
fire1998 is offline
post #6 of 21 Old 07-24-2010, 11:09 PM
oakmckinley
Is it turning over?
I agree that it might be the CPS. I had this fail twice and it gave no check engine light either time.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #7 of 21 Old 07-25-2010, 01:10 AM
Dans95ZJ
I'd put a buck on the CPS.
When you check for the three things and don't get spark, but the coil is good, disconnect the CPS for a while and then put it back. If it starts, great - change the CPS because it wont last.
I had this on my ZJ and I couldn't figure it out for months. Good thing the YJ was working!
Only in My Jeep!
Dans95ZJ is offline
post #8 of 21 Old 07-25-2010, 01:33 AM
DezDiggler
DezDiggler's Avatar
Is it manual? Can you roll start it? Have you tried jumping your starter to rule out ignition? What made you check the fuel pressure?
Robin Hood did not steal from the rich to give to the poor. He gave back what the government took from the people.
DezDiggler is offline
post #9 of 21 Old 07-25-2010, 01:35 AM
DezDiggler
DezDiggler's Avatar
I just had similar problem and it turned out to be my clutch safety switch. Full power, but turn key and nothing.
post #10 of 21 Old 07-25-2010, 07:21 AM Thread Starter
fire1998
It will crank, but will not start. Plenty of battery power.
fire1998 is offline
post #11 of 21 Old 07-25-2010, 07:56 AM
Piratejonh
Piratejonh's Avatar
I had a similar problem and it was the computer. However that seems to be rare.
CPS is a better bet.
Clutch safety switch will prevent power going to relay for the starter, so if it turns over and doesn't start I would look elsewhere.
My clue was the OBDII scanner would not interface with the computer. (And had replaced CPS, checked connections, ruled out starter and ignition)
Oh and in case it comes up, '97 PCM is plug and play, no programming necessary.
Jeep took another piece of my finger today...
Piratejonh is offline
post #12 of 21 Old 07-25-2010, 08:07 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by fire1998 View Post
User Has Not Filled Out Jeep Information.
there is no way we can help you if you dont help yourself first.
Mail crawling.
MisfitSeven is offline
post #13 of 21 Old 07-25-2010, 08:24 AM
Ghaniba
Your symptoms are the same as mine, that it cranks but won't start. Mine died while going down the road the other day. no warning, no sputtering, just off, coasting to the side of the road where she was towed home.
I've found I've got fuel, but no spark. I changed my CPS since I heard they die often, and it made no difference. My code that was thrown on the event was P0351 and then every cylinder misfire happened at that time too. After clearing the codes, I don't get any codes while I crank it.
I'll post in your thread if I find what's causing mine, perhaps it'd help yours too! I'm hoping it's not the ECU!
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline
post #14 of 21 Old 07-25-2010, 08:34 AM
1jack5
See mine did this EXACT same thing and it was my crankshaft position sensor.
1jack5 is offline
post #15 of 21 Old 07-25-2010, 05:23 PM
Dead_End
1990 XJ Cherokee
Had the same problem, and it was the CPS. Just replaced it today
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
no start
91 2.5L wrangler cranks but wont start, fuel problem 91wranleron31mt YJ Wrangler Technical Forum 11 08-20-2012 01:54 PM
Wrangler wont start...sometimes Skullx TJ Wrangler Technical Forum 12 02-23-2011 12:59 PM
88 wrangler wont start 88yj YJ Wrangler Technical Forum 30 04-27-2010 08:22 PM
02 wrangler wont start idnthaveadd TJ Wrangler Technical Forum 2 08-04-2007 11:49 AM
Wrangler problem ... new computer? JeepinJosh TJ Wrangler Technical Forum 3 12-05-2003 07:14 PM
