97 Wrangler SE 2.5 Liter Manual Steering - JeepForum.com
post #1 of 4 Old 07-12-2010, 08:56 PM Thread Starter
bassinbrunner
Can someone point me in the right direction. I have searched, and found most writeups for 98-00 with power steering. I am attempting or needing to replace the serpentine belt on my 97 with manual steering. Where do I need to start? Basically, I guess I'm asking assistance in terms of getting the old belt off and new one on? I'm guessing theres a tension pulley of some sort? Any help would be greatly appreciated and yes, I'm pretty new to all of this!
As stated above, 97 Wrangler manual steering 4CYL.
bassinbrunner is offline
post #2 of 4 Old 07-12-2010, 09:53 PM
freeskier93
Under where the power steering pump should be is the tensioner pulley. To remove the belt loosen the tensioner pulley bolt, but don't remove it. Then if you look behind the pulley you should see a bolt connected to the back side of it. This bolt moves the pulley up and down, either tightening it or loosening it. Turn the bolt counterclockwise until the belt is loose enough to remove.
Even though you have manual steering it's probably all the same. I'm also going to guess that in place of the power steering pump you have a "dummy" pulley.
freeskier93 is offline
post #3 of 4 Old 07-13-2010, 04:16 PM
BlueFlame
BlueFlame's Avatar
Service manuals are quite handy too.
BlueFlame is offline
post #4 of 4 Old 07-13-2010, 05:47 PM Thread Starter
bassinbrunner
Thanks!
Thanks guys!
It's been switched and all is well. Appreciate the insight. Service manual will be in the near future.
tj , wrangler , manual steering , serpentine belt , removal , remove
2.5 liter power steering/vacuum issue RyanEck TJ Wrangler Technical Forum 4 06-04-2009 02:28 PM
97 wrangler with manual steering, need donor info for power steering. anarchyfor2 TJ Wrangler Technical Forum 7 01-12-2009 07:12 AM
fan clutch help!!!! 2.5 liter 1997 wrangler nefferttii TJ Wrangler Technical Forum 2 06-28-2008 07:45 PM
Lower MANUAL steering shaft for 95 wrangler fiddler YJ Wrangler Technical Forum 1 11-12-2006 10:49 PM
will the 5.2 liter bolt up to the 4.0l 5spd manual tranny drtjmpr17 TJ Wrangler Technical Forum 2 03-20-2002 05:28 AM
