97 Wrangler Rough Idle while stopped - JeepForum.com
post #1 of 6 Old 06-22-2010, 06:35 PM Thread Starter
jes229445
Every time I come to a stop my Jeep start running like I have a miss in the engine (2.5). Driving along it runs great. Also if I come to a stop with the AC on it's even worst and my oil pressure drops to zero. Changed plugs, wires, rotor and dist cap, oil changed and cleaned throttle body and IAC. Any more suggestions.
Thanks for any help
jes229445 is offline
post #2 of 6 Old 06-22-2010, 07:27 PM
jmpowie
any codes?
jmpowie is offline
post #3 of 6 Old 06-22-2010, 08:08 PM
Sundowner
Fill in your profile so we know what else you're equipped with!
1. What oil are you using?
2. Have you checked/changed injectors?
3. Did you check the harness/connections to the IAC?
4. Did you check the harness/connections to the TPS?
5. As previously posted, any codes showing?
Sundowner is offline
post #4 of 6 Old 06-23-2010, 02:45 PM Thread Starter
jes229445
I'm getting a code for multiple misfire. I had a friend tell me if could be the speed sensor, since I changed from 29's to 31's. My speedometer is still dead on, and I don't see what that would have to do with anything.
post #5 of 6 Old 11-29-2011, 08:36 PM
big_block_rober
ruff idle
check your wiring harness on the back of the motor, this is a common problem,
the wiring harness rubs and chaffs on the back of the block and valve cover. pull the wire loom off and check the wires for cracks and worn spots. hope this helps
big_block_rober is offline
post #6 of 6 Old 12-01-2011, 10:52 AM
autopc25
Check for vacuum leaks. Do a search, lots written about it.
Good Luck
autopc25 is offline
rough idle
1995 Jeep Wrangler runs rough won't idle serge110 YJ Wrangler Technical Forum 20 01-28-2011 06:22 AM
94 wrangler:rough idle, now no spark mattice YJ Wrangler Technical Forum 2 04-19-2010 05:51 PM
Low idle to stalling when stopped gotmudd1 TJ Wrangler Technical Forum 13 02-03-2010 07:32 PM
1997 Wrangler Rough Idle when cold...please help, newbie in distress seanace1 TJ Wrangler Technical Forum 10 08-10-2009 01:52 PM
1995 Wrangler has rough idle Huskers9855 YJ Wrangler Technical Forum 3 01-23-2008 07:04 AM
