97 wrangler with manual steering, need donor info for power steering. - JeepForum.com
post #1 of 8 Old 01-11-2009, 05:34 PM Thread Starter
anarchyfor2
hey all, i recently started purchased my tj and noticed i was having a leak from my steering box, so i was gonna replace it . well once i got under my jeep, i noticed that i had manual steering in my 97. me, and several other jeepers were unaware that this was an option. IT IS!!! my question, is anyone aware of another vehicle that i could pull the pump, res. gearbox and bracket off of to go in mine, i know i can use a durango gearbox but what else can i use. my jeep has the 2.5l and my local yard couldnt get me any info. im gonna hit the yards tomorrow, so hopefully i can get this started.
"If i had a dollar for every time something broke, i might be able to afford this thing"
anarchyfor2 is offline
post #2 of 8 Old 01-11-2009, 05:50 PM
DBLJ
DBLJ's Avatar
a TJ with PS?
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #3 of 8 Old 01-11-2009, 06:59 PM Thread Starter
anarchyfor2
yeah, i guess thats the obvious answer but i havent found a tj at a yard within 300 miles of my house
post #4 of 8 Old 01-11-2009, 07:09 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have a PS pump from my 99 with 2.5, should bolt right up make an offer
RnEmOvr is offline
post #5 of 8 Old 01-11-2009, 07:55 PM
RLD831
RLD831's Avatar
If your Jeep did not come with PS stock, then it probably doesn't have the clip to hold the reservoir. I used a PS pump out of a 6cyl TJ in my 4cyl. It is the exact same pump and bolts right up, but the reservoir is built into the pump.
RLD831 is offline
post #6 of 8 Old 01-11-2009, 09:32 PM Thread Starter
anarchyfor2
give me a ball park that you need for it, i have no idea, another question, the yards in my area have a blue ton of zj and wj , any chance i can get part from them?
RnEmOvr- pm me and we can work something out. after the pump, i would only need the steering box correct and i guess a belt also correct?
post #7 of 8 Old 01-11-2009, 09:36 PM
jcssurf
Oh my god. I can't imagine turning 33x12.50's with manual steering. I've driven a CJ and Landcruiser with manual steering and 33x12.50's. They both had huge solid steering wheels, and it still sucked.
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline
post #8 of 8 Old 01-12-2009, 07:12 AM Thread Starter
anarchyfor2
ts really not tthat bad, but i figure i have to replace the box, might as well make the upgrade
Manual to Power Steering Question 13mx YJ Wrangler Technical Forum 8 09-26-2009 05:33 PM
Manual or Power steering mfolkmann YJ Wrangler Technical Forum 9 06-05-2007 10:33 PM
Power to manual steering?? SafetyMan YJ Wrangler Technical Forum 8 05-07-2006 01:13 PM
Manual to Power Steering conversion? a1988yj YJ Wrangler Technical Forum 0 04-12-2004 02:28 PM
Manual ---> Power Steering southerndawg YJ Wrangler Technical Forum 5 06-22-2003 03:19 PM
