97 Wrangler High Idle HELP!!! - Page 3 - JeepForum.com
post #31 of 41 Old 10-18-2010, 09:28 AM
creepyjeep420
mine was doing that and i replaced the throttle position sensor. helped me.. if you have a check engine light on go to a mechanic and get them to run a diagonistic that should tell you exactly what it is
creepyjeep420 is offline
post #32 of 41 Old 10-20-2010, 05:04 PM
twanger1994
I don't have a cel on and I'm sure it lights
twanger1994 is offline
post #33 of 41 Old 03-20-2013, 01:40 PM
Erhmagerdjerp
I had this same issue on my 97 tj. I replaced the Iac and the tps I replaced the vacuum line (from this fuel rail to the throttle body) I wa at a loss...just for fun I sprayed a little throttle body between the intake manifold and the block. It made the engine stumble and sputter...turns out the bolts holding the intake on were loose...it works fine now so try it out
Erhmagerdjerp is offline
post #34 of 41 Old 03-20-2013, 01:58 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Thanks for the help, though note the post you responded to was nearly three years old. A big welcome to JF, good to have you here!
Jerry Bransford is offline
post #35 of 41 Old 05-27-2014, 07:06 AM
Bullethead
I have replaced my IAC, cleaned the TB 3x and still nothing. I did notice that upon spraying Carb cleaner at the line from the PCV elbow to the Intake Manifold there was a stutter.
Could you show me the bolts you are referring to? I am not sure if I need to replace the vacuum line or what. I am one weekend away from just taking this to the mechanic and washing my hands of this issue. Should I look into replacing the TPS as well? because a new IAC didn't do a darn thing but make it worse.
Bullethead is offline
post #36 of 41 Old 10-18-2014, 10:05 PM
BLAKESTER
Man this sucks I put a new exhaust my 1999 jeep wrangler , unhooked all the electrical , pulled the manifold to the side replaced the exhaust. put everything back, started it now its full throttle wide open, can some one please help me out on this . THX BLAKESTER
BLAKESTER is offline
post #37 of 41 Old 10-18-2014, 11:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Sounds like you didn't get the intake manifold installed properly on the alignment dowel pins. Check the link below... HTH
http://www.jeepforum.com/forum/f9/in...ectly-1045108/
Knuckelhead is offline
post #38 of 41 Old 10-18-2014, 11:39 PM
Jerry Bransford
Administrator
The intake manifold is leaking where it bolts to the head from not having been seated properly.
post #39 of 41 Old 10-23-2014, 07:56 PM
BLAKESTER
Just wanted to say think's for the help "work's great " took it off an put it back on
post #40 of 41 Old 12-16-2014, 09:01 AM
jtleitner
High Idle @2000 RPM and a whine like it's sucking air
My 99 TJ 4cyl started to slowly increase the RPM.
First it would (periodically) crank but not start. I had a mechanic replace the Crank sensor and when I got it back, it seemed to work ok. Then a day or so later, I turned a corner a little fast and everything seemed to shut off. I had been having this increasing idle issue and thought I had a vacuum leak. So I finally reached around back of the throttle body (while it was running) and messed a little with the wires. I did this actually looking for a vacuum leak. I must have moved the connections to the throttle body and the thing stopped running and picked back up as I wiggled the wires around.
I pulled the airbox off and discovered the plastic connector lock was broken off both connections. The essence of why my Jeep wouldn't start and more recently stopped running when making a turn. Basically I wasted a lot of money having a crank sensor replaced when all along it was these two loose connector blocks on the back of the throttle body. Arggghhhh.
So that being fixed, I still have an issue with the whistle I'm now getting and the high idle. Reading this thread, I'm thinking it's either loose manifold, broken vacuum line or the Throttle Air motor. I'm taking the thing to a mufflr shop today because the whistle I'm getting started happening around the same time as the higher idle. If that diagnosis doesn't indicate an obvious repair, I'll look into the Throttle Air sensor. I'll let you all know what I find.
JTL
Red Fred 1999 TJ
jtleitner is offline
post #41 of 41 Old 05-17-2016, 01:03 PM
rfailing
High Idle speed when warmed up! Fixed!
Originally Posted by tomvid View Post
Well, back to the drawing board. I cleand out the IAC valve and housing at with no effect. I did the TPS voltage test and it came back like this. 5V Incoming voltage. Which is correct. I did the output to test and at WOT it only read 3.9V when I was opening the throttle. I couldnt get it to go over 3.9V Should the range on a proper TPS get me closer to 5V? Does anybody know what the proper Volt range is?
Thanks Guys....
Only 6 years late, but for what it's worth! I bought a 93 6 cyl last fall, never ran right. Did a lot of guessing, sent PCM to get analyzed to a guy in Ohio, he changed the capacitors and said it tested fine. Reinstalled, cleaned throttle body and IAC thoroughly. I didn't have a high idle problem until reinstalling the rebuilt PCM. LONG STORY SHORT, I had loose tranny bolts discovered when my mechanic replaced the clutch slave cylinder, and he told me to ck other bolts. Turned out my high idle problem was caused by loose intake/exhaust manifold bolts!!!! Tightened them all and voua-la engine runs perfect. My mechanic replaced O-rings on injectors also. Now I know how to do that, but if you put your hand over the throttle body while running, the engine should stall. If it keeps running you have an air leak - either cracked manifold, open holes or loose bolts! Mine is fixed.
rfailing is offline
high , idle
Low Idle Cold, High Idle Warm Lon33 YJ Wrangler Technical Forum 13 10-29-2014 09:24 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
Dead battery, no idle, now high idle. HELP! gudoldboy TJ Wrangler Technical Forum 0 06-29-2008 02:31 PM
'89 Wrangler 2.5L - High idle after warm - Help? Rich in Almaden YJ Wrangler Technical Forum 4 04-04-2005 02:10 PM
