97 Wrangler High Idle HELP!!! - JeepForum.com
post #1 of 41 Old 06-18-2010, 11:45 AM Thread Starter
tomvid
I have a 97 Wrangler. The other day it started to idle high. It Idles at 2200 rpm. It is not speratic. It runs just like it should but at 2200 RPM. I think it may be a vaccum leak somewhere but I looked everywhere and couldnt find one. Another thing that is puzzeling me is that I have no check engine light on. I did some tests on the Throttle Position Sensor and ruled that out as the problem. Any suggestions would help out greatly, I am stumped on this one.
tomvid is offline
post #2 of 41 Old 06-18-2010, 12:03 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Welcome to the fourm.
Have you cleaned the throttle body lately?
If not, I would start there.
And make sure to clean out the IAC really well.
Wheelin98TJ is offline
post #3 of 41 Old 06-18-2010, 12:24 PM Thread Starter
tomvid
Hey thanks for the reply. Yeah, I cleaned the throttle body out really well. Seems to be closing and operating correctly. I was pointing to the IAC. Do I clean out the motor or the sensor or what?
tomvid is offline
post #4 of 41 Old 06-18-2010, 12:25 PM Thread Starter
tomvid
Also, wouldnt the IAC cause the check engine light to come on?
tomvid is offline
post #5 of 41 Old 06-18-2010, 12:40 PM
Sundowner
It might. Or not. You might have a slight leak in the intake manifold somewhere, as well. That will cause the throttle to race, but otherwise respond.
Sundowner is offline
post #6 of 41 Old 06-18-2010, 12:42 PM
Wheelin98TJ
JEEP FREAK
Clean out everything in and around the IAC including the passage inlet.
Q-tips work well for this.
Sometimes it will throw a check engine light, sometimes not. Bad sensors can fly under the radar sometimes.
post #7 of 41 Old 06-18-2010, 12:44 PM Thread Starter
tomvid
Sounds like a plan. I'll give it a shot this weekend and see what I can come up with.
Thnaks for the input guys. Much Appreciate.
tomvid is offline
post #8 of 41 Old 06-28-2010, 12:57 PM Thread Starter
tomvid
Well, back to the drawing board. I cleand out the IAC valve and housing at with no effect. I did the TPS voltage test and it came back like this. 5V Incoming voltage. Which is correct. I did the output to test and at WOT it only read 3.9V when I was opening the throttle. I couldnt get it to go over 3.9V Should the range on a proper TPS get me closer to 5V? Does anybody know what the proper Volt range is?
Thanks Guys....
tomvid is offline
post #9 of 41 Old 06-28-2010, 01:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Has the intake manifold been worked on or removed/reinstalled? As would happen if the exhaust header was replaced.
Jerry Bransford is online now
post #10 of 41 Old 06-28-2010, 01:15 PM Thread Starter
tomvid
Yes it has, It was replaced about two three years ago but I found no leaks anywhere on or near the manifold...
tomvid is offline
post #11 of 41 Old 06-28-2010, 01:18 PM
Jerry Bransford
Administrator
Leaks are often hard to locate but my guess, since you have already cleaned the IAC, is a vacuum leak. How about spraying some WD-40 at where the intake manifold bolts to the head while the engine is running to see that makes the engine rpms change.
post #12 of 41 Old 06-28-2010, 01:22 PM Thread Starter
tomvid
Been there. Like I said... Couldn't find a thing. It is very frustrating!!! Jerry, do you know if I should be getting an output reading higher than 3.9V at wide open throttle?
tomvid is offline
post #13 of 41 Old 06-28-2010, 01:24 PM
Jerry Bransford
Administrator
I'll have to see if my FSM (factory service manual) gives that information but it's at home, I'll look tonight if no one else answers that question by then.
post #14 of 41 Old 06-28-2010, 02:14 PM Thread Starter
tomvid
You rock Jerry... Thanks!
tomvid is offline
post #15 of 41 Old 06-28-2010, 02:39 PM
Wheelin98TJ
JEEP FREAK
It is supposed to gradually increase up to 4.5 volts at wide open throttle.
3.9 is typical and its nothing to worry about.
high , idle
Low Idle Cold, High Idle Warm Lon33 YJ Wrangler Technical Forum 13 10-29-2014 09:24 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
Dead battery, no idle, now high idle. HELP! gudoldboy TJ Wrangler Technical Forum 0 06-29-2008 02:31 PM
'89 Wrangler 2.5L - High idle after warm - Help? Rich in Almaden YJ Wrangler Technical Forum 4 04-04-2005 02:10 PM
