97 wrangler blows cool air for heat - JeepForum.com
post #1 of 1 Old 11-01-2008, 08:39 AM Thread Starter
Mikerp97
I've replaced 192' with 180' thermostat, did not work, heater core supply hose gets hot, return is not so hot so I thought core was clogged but I am able to blow air thru supply line almost as easy as thru a new core, I don't want to replace core only to find out it is something else, could it be water pump not moving water hard enough? how can I test for this?, I do not have an overheating problem
owers of:
91 jeep wrangler sport 2.5L 4" rough country lift, 3 inch body lift, 35x14-15 ground hog tires, smittybilt XRC-8 winch, dana 30 front, ford 8.8 rear welded
Mikerp97 is offline
Wrangler has poor heat and runs cool RednekWrangler YJ Wrangler Technical Forum 50 10-24-2013 02:55 PM
heat only blows out of defroster ibkushman320 TJ Wrangler Technical Forum 6 03-28-2010 06:31 AM
2003 TJ Only Blows Cold Air and No Heat Abathur TJ Wrangler Technical Forum 1 11-23-2009 08:10 PM
Heat, blows more air when jeep is off??? jaminb YJ Wrangler Technical Forum 1 02-19-2008 03:46 PM
Heat Blows When Off dman22 TJ Wrangler Technical Forum 2 01-30-2007 06:17 PM
