97 TJ wrangler 4 cyl Rough idles low compression - JeepForum.com
post #1 of 2 Old 08-01-2010, 12:24 AM Thread Starter
GLKRUEG
I have a 97 tj wrangler that all of a sudden started running rough on a trip, I took it to a mechanic who said one of the cylinders had low compression and the engine was no good. What I dont understand is that after changing all the spark plugs, cap rotor...it still runs rough at idle but it wont stall and even though it has less power and will still run for long distances. Could this be a valve problem or an electrical problem. I cant believe that the engine could just go like that and it still runs fine now just without power and rough idle. Any help out there???
GLKRUEG is offline
post #2 of 2 Old 08-01-2010, 12:46 AM
Sundowner
Originally Posted by GLKRUEG View Post
...I took it to a mechanic who said one of the cylinders had low compression and the engine was no good...
Any explanation for this? Low compression - while potentially a serious problem - doesn't absolutely mean that the engine is "no good."
Sundowner is offline
rough , idle , low , compression
2.5L idles rough and stalls when accelerating YJNEWBE YJ Wrangler Technical Forum 0 08-08-2009 09:15 PM
4.0 idles rough when re-started CleanRedYj TJ Wrangler Technical Forum 5 04-19-2009 10:44 PM
4.2L idles rough mattmash YJ Wrangler Technical Forum 6 11-30-2008 08:35 PM
4.2 idles rough when cold tet-ness-shot YJ Wrangler Technical Forum 3 08-13-2008 02:12 PM
4.0 idles rough.. have 6 engine codes.. mikevsgeek TJ Wrangler Technical Forum 1 09-17-2007 05:27 PM
