97 TJ won't fire but only sometimes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 97 TJ won't fire but only sometimes
Ruffstuff XJ Unirail Channel Reinforcement....The Original 3/8" Ruffstuff Diff Cover!Gibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-02-2015, 04:19 PM   #1
kjhickey
I just put in a new battery (2 weeks old) as well as a new starter. New fuel pump too.
When I turn the ignition to the on position everything lights up and beeps so the battery is obviously good. When I turn the ignition to start it, I get nothing. However it is only some of the time. The times that it does fire, it starts right up (no check engine light). It can go days and several attempts without firing and then the next time I try, it starts right up. I'm wondering if it's either electrical or the actual key/ignition has an issue. Any thoughts on what to check? anyone?
kjhickey is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 04:46 PM   #2
RockMonster
Hopefully it's just a bad ground
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++++++
RockMonster is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 07:00 AM   #3
kjhickey
It's a good place to start- thanks
Unread 08-03-2015, 11:00 AM   #4
JWebber
Check your ignition switch at column. Also what can happen is the ignition driver can break inside steering column. You will have to remove the cover and metal cover to access, you will need a tamper proof small torx bit set to even remove the cover to these parts.
JWebber is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 01:03 PM   #5
Rubi4MyMrs
Rubi4MyMrs's Avatar
When you turn the key & it doesn’t fire up are the volt & fuel gauges moving up?
If yes then possibly what JWebber says. Here is a link with more details on checking that.
http://www.wranglerforum.com/f210/st...l#post20609745
Rubi4MyMrs is offline   Reply With Quote Quick reply to this message
Unread 08-04-2015, 05:11 AM   #6
kjhickey
ok- thanks JWebber.
Rubi4MyMrs- that's a good question, I'll have to check if the gauges move when I turn it on. Thanks for that link too- seems very similar to what is going on with mine.
Back to the "lab"- a friend of mine is a mechanic so I'm going to see if he can help me- I'll post the results. Thanks again to all 3 of you!
Unread 08-25-2015, 06:05 AM   #7
kjhickey
turns out it was the backup/neutral starter switch- it was broken and needed to be replaced- problem fixed.
