97 TJ Tranny issue - JeepForum.com
post #1 of 7 Old 08-21-2011, 12:48 AM Thread Starter
stofur
97 TJ Tranny issue
Hey guys...I'm new to the forum and new to Jeeps in general. I'm also not mechanically inclined, but I bought a Jeep so that I could learn. Looks like I'm going to get my chance...
Here's my issue. My TJ slips out of 5th gear typically after I let off the gas, coast, or sometimes if I hit a big bump in the road. Any ideas what would cause this? The only gear I have trouble with is 5th...
I'm concerned that it could be the tranny and I don't have the money right now to rebuild/replace it as I used all my cash to buy it.
Your help is very much appreciated!! Thanks!
stofur is offline
post #2 of 7 Old 08-21-2011, 02:43 AM
predawn
mileage?
predawn is offline
post #3 of 7 Old 08-21-2011, 08:05 AM
herbiehind
you could try adjusting the shift linkage according to a shop manuel . if that fails , start saving for a second hand on cr's list , and rebuild yours while it's out .
http://www.greatlakesxj.com/tech/AX15.pdf
i see no adjustments to shifting as it is internal . the pdf is good but if you go to great lakes and scroll down you will find 97 xj service manual ,containing a much better tranny section with better photos . also lots of engine stuff . looks like a gear issue or rail or syncro . it's as if the gear isnt fully engaging . try the engine/driveline section of this site . very helpful folks here .
herbiehind is offline
post #4 of 7 Old 08-21-2011, 08:33 AM
skydiver30960
nOob for life
skydiver30960's Avatar
Definitely not trying to over-simplify things, but I'm a noob too so that's what I do. Start out by looking at the shifter and your center console and make sure they aren't hitting for some reason. Pop loose the bezel that holds the rubber boot in place to really get it out of the way to see if it still keeps popping out.
Ike
I will NOT calm down! Machine guns affect my ability to perform and I do NOT like that! -- Ricardo Tubbs
I AM FENWICK!
skydiver30960 is offline
post #5 of 7 Old 08-21-2011, 03:46 PM
herbiehind
Ike
that's an awesome point . could have a body lift or t-case drop .
post #6 of 7 Old 08-21-2011, 05:49 PM Thread Starter
stofur
Ike
Tried loosening the bezel...still popping out of 5th.
stofur is offline
post #7 of 7 Old 08-21-2011, 05:51 PM Thread Starter
stofur
Thanks herbie. I will probably give it a try next weekend. I'm such a noob tho, I'm afraid of messing stuff up. Since it's my daily driver, I can't really afford a mistake. I'm gonna check out greatlakes tonight. thanks again!
stofur is offline
tranny problem
tranny issue victor66 TJ Wrangler Technical Forum 1 01-02-2010 06:44 PM
Tranny Issue Mike-In-Mass YJ Wrangler Technical Forum 3 09-16-2008 01:32 PM
YJ Tranny Issue jeddy53824 YJ Wrangler Technical Forum 13 01-28-2008 07:58 PM
Tranny issue? Macabre YJ Wrangler Technical Forum 5 09-03-2007 11:17 AM
Tranny Issue TellyDSP TJ Wrangler Technical Forum 2 10-27-2003 02:09 PM
