97 TJ stalling around heavy turns with 1/4 tank of gas? - JeepForum.com
post #1 of 15 Old 01-31-2006, 01:49 PM Thread Starter
skyjacked94xj
skyjacked94xj's Avatar
Hey fellas, I have a 1997 TJ with the 4.0 and 5 speed. I had alittle over a 1/4 tank of gas today and I made a right hand turn and the jeep cut out for a couple second then kicked back in.. Its obviously a fuel problem. Like its running out of gas. Now I am awhere of that the gas sloshes around in the tank but should that cause it to almost shut off even when there is a 1/4 tank of gas???
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline
post #2 of 15 Old 01-31-2006, 01:58 PM
JeepNazi101
JeepNazi101's Avatar
I have heard of that happening mostly on CJ's though.
"Professional Driver on a Closed Course"
i has a kool buggy
JeepNazi101 is offline
post #3 of 15 Old 01-31-2006, 02:03 PM
spqrtj
i have a 97 tj same thing happens to me. I beleive the fuel pump isnt getting fuel when u take the turn. My friends 97 cherokee also does this
spqrtj is offline
post #4 of 15 Old 01-31-2006, 03:33 PM
gUanoTJ
I had this happen several years ago on my 97 TJ. It turns out that my fuel pump was going...ended up frying alltogether before I figured it out. I replaced it, changed the fuel filter and have had no problems since. I paid an arm and a leg to let the stealership do the repair, but you could probably do it yourself and save a couple hundred bucks.
gUanoTJ is offline
post #5 of 15 Old 01-31-2006, 05:46 PM
muddyforeman
I too am fighting the same problem. More than likely the "socks" on the pump are clogged up. Our fuel pumps use two. You have to drop the tank to put em, so it may be in your best interest to replace you pump depending on its age. FYI You can buy a Replacement pump and socks Made by Carter at Advance for about 80$. From the dealer its a whole assembly close to 300$ yet i have been told that Jeepsareus has them for 224$.
whatever you do, dont get the Master Brand replacement THEY SUCK!
hth
97 TJ, s35 Detroit, Open 30, 33"mtrs, 4" Skyjunker Lift, Kilby Tank Skid, Fabtech Steering Skid 2.5 Super Low Output 4 Banger
muddyforeman is offline
post #6 of 15 Old 01-31-2006, 05:47 PM
muddyforeman
ps, If you choose to replace just the "socks" they can be had for about 15$ the main sock is in stock @ most advance stores and the 2nd is an overnight part
post #7 of 15 Old 01-31-2006, 05:58 PM
DietCola
I had this same problem the week after I bought my 97 TJ. I had the dealer replace the fuel pump and everything was good...till the starter went but that was another issue.
Need 33x12.50x15 spare!
'97 TJ - 4cyl - 5spd
3.5" Rubicon Express Super Flex
33x12.50x15 Firestone Destination M/Ts
15x8 Crager D-Hole Rims
DietCola is offline
post #8 of 15 Old 01-31-2006, 06:09 PM
FifteenCents
not a corvette
My buddy had the same problem, I told him to keep it at least half full and drive it like a jeep and not a corvette and he has not had any problems lately
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #9 of 15 Old 01-31-2006, 07:41 PM
muddyforeman
well not a bad idea, unless you have a 15 gallon tank, at 15mpg, and having only a usable 7-9 gallons of usable space, that makes the gas stations too freindly to me!
post #10 of 15 Old 02-01-2006, 09:47 AM Thread Starter
skyjacked94xj
I'll second that. I get only around 12 mpg. I WOULD LIKE TO KNOW WHY! but thats another issue. I am always at the gas station.
DAILY DRIVER
CLASSIC TOY
Project
post #11 of 15 Old 02-01-2006, 02:29 PM
Grimmjpr
My 97 Sport used to do that.....the sending unit was off. Most 97 Sport's i've seen have almost all had the upgraded 19 gallon tank. On mine the sending unit was off so i was actually running out of gas even though the gauge was reading 1/4 tank or so. I ran it like that for a long time. I ended up selling that Jeep....my buddy that bought it replaced the pump/sender/filter assembly and its all good now.
2012 JK Rubi - Cosmos Blue/5 speed auto
04 TJ Electric Lime Green Rubicon - Bunch of extras. Cha-Ching - Gone
97 TJ Lapis Blue Sport - Gone
Grimmjpr is offline
post #12 of 15 Old 02-01-2006, 07:10 PM
muddyforeman
I thought the same Gimmjpr, but it only takes 10 gallons to fill up so i know my sending unit is right
post #13 of 15 Old 02-01-2006, 07:59 PM
Grimmjpr
Muddy, Is your gas skid badly dented? Sounds kinda strange....
Grimmjpr is offline
post #14 of 15 Old 02-01-2006, 08:17 PM
muddyforeman
none that i can see grimm. The whole problem started when i poured about 4 gallons in through a funnell. Ever since, 1/4 tank and im sputterin around the corners, Im thinkin the sock is almost stopped up. I guess I wont know till i drop the tank a take a look around
post #15 of 15 Old 02-01-2006, 08:44 PM
meengineer2006
Fuel Pump Replacement
My jeep did the same thing, only it got so bad that it would do it just going down the road. The dealership wanted too much so I just replaced everything myself. I bought the two socks and the regulator/filter and a OEM Bosch fuel pump for $140 from this guy. http://stores.ebay.com/FUEL-PUMP-KIN...Q3amesstQQtZkm
I have over 10,000 miles on my repairs and still going strong. IMO the Bosch is much better than what they sell at any local autoparts, and cost about the same ($89).
meengineer2006 is offline
OME HK (Heavy Duty) Suspension Kit- Launch Time Without Heavy Bumper? hikerpaddler TJ Wrangler Technical Forum 8 03-11-2009 11:50 AM
Starter Turns, Motor Turns, Have Spark Still No Start greenerob YJ Wrangler Technical Forum 7 11-14-2008 03:33 PM
Turns off at sharp turns and bumps transam402002 YJ Wrangler Technical Forum 6 10-26-2006 01:32 PM
1/4 Tank = Stall Out On Sharp Left Turns codyman YJ Wrangler Technical Forum 12 01-29-2006 11:16 PM
Stalling Stalling Still Ahhhh ahdblo7 YJ Wrangler Technical Forum 1 08-21-2002 08:17 PM
