'97 TJ with slipping transmission - JeepForum.com
post #1 of 6 Old 06-06-2012, 12:29 PM Thread Starter
silentmike29
1986 CJ10
Hey everyone, I actually own a 78 CJ but I have a friend with a '97 TJ with a 4 cylinder engine and automatic tranny. It doesnt sound the greatest and she said when going from 2nd to 3rd it takes awhile to get into 3rd, which i assume she meant it is slipping. Is this common with these jeeps? and what kind of transmission work can she expect?
Roll one. Smoke one. When you live like this you're suppose to party..
silentmike29 is offline
post #2 of 6 Old 06-06-2012, 12:45 PM
BamaJeepman21
How many miles does it have? I'd check the fluid level first.
-Jack
BamaJeepman21 is offline
post #3 of 6 Old 06-06-2012, 01:09 PM Thread Starter
silentmike29
1986 CJ10
Thanks for the response. It has 97,000, going to try the cheapest fix first and check the transmission fluid levels. Thanks so much for the response, I will update as soon as I can!
post #4 of 6 Old 06-06-2012, 01:18 PM
JBTJ
Sounds like the filter and ALL of the ATF needs to be changed out, and not what is just in the pan like most folks do.
JBTJ is offline
post #5 of 6 Old 06-06-2012, 02:11 PM Thread Starter
silentmike29
1986 CJ10
thanks guys
post #6 of 6 Old 06-06-2012, 03:09 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have the fluid changed (all of it) and change the filter. While the filter is being changed, have the two clutch band adjustments done as called out in the OEM FSM...
Knuckelhead is offline
Transmission slipping?????? KenG TJ Wrangler Technical Forum 5 04-01-2011 06:40 PM
transmission slipping cb19950 TJ Wrangler Technical Forum 14 04-28-2007 03:34 PM
Transmission Is Slipping schooner TJ Wrangler Technical Forum 1 10-30-2006 03:55 AM
Transmission slipping?? Help needed please jrtew TJ Wrangler Technical Forum 3 07-15-2006 01:51 PM
Transmission slipping dukesmj TJ Wrangler Technical Forum 3 05-12-2004 04:42 PM
