Quantcast '97 TJ rear floor metal drain plugs help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > '97 TJ rear floor metal drain plugs help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 08-26-2008, 12:02 PM   #1
sportcoupe
My '97 TJ has metal drain plugs in the rear passenger floor that were sealed in and painted over by the factory. I removed them using force and they are of course not re-useable.
Does anyone make a rubber replacement plug for these metal ones? Remember they are not round, they are oval making it a little harder to find something at the local hardware store.
Thanks!
sportcoupe is offline   Reply With Quote
Old 09-07-2008, 05:58 PM   #2
BoonDoggy
let me know when you get an answer as I have been searching this issue ad-nausium for 2 days. Morris 4x4 in pompano, fl had them 2 months ago but now I don't see anywhere on their site.
BoonDoggy is offline   Reply With Quote
Old 09-07-2008, 06:11 PM   #3
RnEmOvr
Never Forget
RnEmOvr's Avatar
those were not designed to be removed, that was done by the factory, you dont need plugs anyway
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 09-07-2008, 06:37 PM   #4
billbanshee
id love to find rubber plugs for those too i dont really want to glue them back in or run without them this winter
98 tj sahara
re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears
bulletproof bumpers/tomken skids/tor roll cage
warn 9000i
billbanshee is offline   Reply With Quote
Old 09-07-2008, 06:40 PM   #5
dualtjs
dualtjs's Avatar
Did you look at the following website (bottom of the page)? Doesn't have a pic, so you will want to call first....
http://www.jeep4x4center.com/tj/floormats-nifty-96-00AT.htm
dualtjs is offline   Reply With Quote
Old 09-07-2008, 07:34 PM   #6
Apex
Recon death squad
Apex's Avatar
umm...you mean the ones that are almost flush with the tub? cause there is a pair in the front floorboards too i think.
and yes they werent designed to be removed...
SOLDSilver 02 TJ Apex Edition. "Pandora"
3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff
IndyORV
Apex is offline   Reply With Quote
Old 09-07-2008, 07:46 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The rear plugs on a '97 as the OP is asking about are not drain plugs and they were not designed to be removed. Later model TJs have removable rear drain plugs.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 09-07-2008, 09:06 PM   #8
Vandano
You could always grab a hole saw and drill a round hole in the floor boards and then get a round drain plug to put in its place.
Vandano is offline   Reply With Quote
Old 09-08-2008, 03:01 AM   #9
brian674
Why did you take them out?
DON'T READ THIS!
brian674 is offline   Reply With Quote
Old 09-08-2008, 10:23 AM   #10
patricknolan
I just drilled a half inch hole in each. I dont even really to plug them ever so i never looked into that but im sure if you drill a standard size then someone will have a plug. Also id recommend painting the new hole where you see any shiny metal because uncovered metal will rust alot quicker than painted metal.
patricknolan is offline   Reply With Quote
Old 09-08-2008, 11:22 AM   #11
sportcoupe
Because they are the only drain plug in the rear footwell of a '97 TJ as stated earlier.
I assumed they were available aftermarket in rubber, I was wrong.
Old 09-08-2008, 11:46 AM   #12
97casteeltj
when water is in that area, just pull the front floor board (rubber) plugs and drive around the water flows through an area and drains it all out through the front holes....works for me, i never thought about taking the metal painted ones out; didn't think i was suppose to!
needing a new rig....
97casteeltj is offline   Reply With Quote
Old 09-08-2008, 04:21 PM   #13
BoonDoggy
Found em!
YES!!!
Those are it. I confirmed it with the local jeep dealership today.
Mopar part number: 550360966-AA Over the counter or
Locally found at Morris 4x4
http://www.jeep4x4center.com/product-information.asp?number=55360966-AA
Old 09-09-2008, 02:52 AM   #14
sportcoupe
Originally Posted by BoonDoggy View Post
Found em!
YES!!!
Are those metal? If so no big find. If they are rubber then you found what I'm looking for.
Old 09-09-2008, 04:40 PM   #15
BoonDoggy
Soft chewy plastic with a crunchy metal inside. Let me know when you get the big find. I searched for a long time and found crappola. hole is Oblong 1 1/8 x 1 3/4". Good luck.
Glock Forum
