97 TJ rear end problems - JeepForum.com
post #1 of 5 Old 02-12-2012, 12:22 PM Thread Starter
Nberry90
I have a 97 TJ with a Dana 35 rear end. When i am driving there is bad vibrations going straight, but worse while turning at any speed. I jacked up the Jeep and i can pull the wheel away from the axle about a half an inch on the passenger side and about 1/4 inch on the driver side. I am not sure if there is a simple fix for this or what is completely going wrong. My jeep is my DD and i need this fixed ASAP. Any suggestions?
Thanks,
Nick
Nberry90 is offline
post #2 of 5 Old 02-12-2012, 12:43 PM
Jeepsr4me
Check the drive shaft. What you describe about the rear axles is normal.
Jeepsr4me is offline
post #3 of 5 Old 02-12-2012, 12:44 PM Thread Starter
Nberry90
the drive shaft and all the U-Joints are fine. thats why i believe that its the differential.
Nberry90 is offline
post #4 of 5 Old 02-12-2012, 02:56 PM
97lon
Pull the cover off of differential and have look. Sounds like your carrier is loose . Thats thing in middle with little gears in it. Atleast if you take it somewhere you know what you got
97lon is offline
post #5 of 5 Old 02-12-2012, 03:13 PM
wwch99tj
Mine did that and the bearings had gone bad on the carrier allowing the whole carrier to move around in the housing. I rebuilt it myself for less than 100 bucks. I had napa press the new bearings on for me
wwch99tj is offline
rear end problems AJM YJ Wrangler Technical Forum 2 04-07-2011 07:48 PM
rear end problems ionakana YJ Wrangler Technical Forum 1 06-23-2009 04:10 PM
Dana rear end problems! Sep YJ Wrangler Technical Forum 10 03-31-2009 10:38 AM
Rear End Problems? 01blackws6 YJ Wrangler Technical Forum 12 11-17-2008 10:54 AM
rear end problems YJ4x4on35'z YJ Wrangler Technical Forum 2 08-29-2003 06:10 AM
