97 TJ, is it possible running 33X10.50s - JeepForum.com
post #1 of 54 Old 08-04-2010, 03:46 PM Thread Starter
JustJeepin85
I currently have 31X10.50s and i am currently wanting to get 33's and sooner the better. Currently i dont have the spare money to put a suspension lift on and really dont want to put on a BL. i was thinking with factory suspension and tubed flares i would be ok in the front, but how will it be affected in the rear?
also will i have problems off road with this setup?
and for a bigger dream would 33X11.50s suck under ok? i dont like to off road hard core as it is my DD and i cant afford to fix it everytime i tear it up, currently battling death wobble till my steering assembly gets here
any suggestions would be greatly apreciated, thanks in advance
Jordan
JustJeepin85 is offline
post #2 of 54 Old 08-04-2010, 03:53 PM
CCGRUNT0331
Do yourself a favor and save up for a BB (budget boost), cheaper than you think...
97 wrangler budget boost - Google Product Search
2000 TJ Sport: SOLD!
2008 JKU Rubicon: aka 'Bruiser'
CCGRUNT0331 is offline
post #3 of 54 Old 08-04-2010, 04:19 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
i ran 33x10.50x15s on my 98 with no lift. the least you should do is trim your flares. because if you dont, when you hit the brakes your tires will self clearance the front flares.
Mail crawling.
MisfitSeven is offline
post #4 of 54 Old 08-04-2010, 04:31 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Avoid all dips and speed bumps!
GOLENJEEPTJ is offline
post #5 of 54 Old 08-04-2010, 04:35 PM
thirdeye
why get 33's if it's your DD?
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #6 of 54 Old 08-04-2010, 04:38 PM
MisfitSeven
MAiL Crawler.
are your 31s bald? if you bought another set of 31s, you could buy a budget boost or even the RC 2.5" lift with the money you saved. or try to find a used set of tires to get you by. buy a lift when you can and then tires.
Mail crawling.
post #7 of 54 Old 08-04-2010, 08:57 PM Thread Starter
JustJeepin85
i can prolly last on my tires till snow hits... think ill throw 2.25" spacers under it i know i will need bump stops for the rear. will i still need tubed flares then? i knew spacers might be an option but didnt think it would help all that much what is your thoughts on spacers? will the spacers allow me to throw the 33X11.50s on?
post #8 of 54 Old 08-04-2010, 09:34 PM
Demp
with 2.25 lift the 33s will fit height wise. You might rub if you disconnect and hit a pretty good bump/hole.
Also if you are running stock rims, 11.5 wide tires will rub your rear spring perch. Check out the backspacing on the rims you have.
Edit: shame on me for not linking to the backspacing post
FAQ- What size tires can I fit on my TJ
Demp is offline
post #9 of 54 Old 08-04-2010, 10:01 PM Thread Starter
JustJeepin85
i believe i have spacers on the i just bought the jeep in september of last year and ive not done anything but play with it lol. but the wheels stick out about 1.5-2" from stock fender flares so i assume theres spacers installed and by the way it looks when i hit the tiniest of mudholes makes me think it has to have spacers:/ havent actually looked or even thought to look should prolly get on that lol
post #10 of 54 Old 08-04-2010, 11:35 PM
thirdeye
take some picutres of the springs, anyone here can tell you if there's a spacer or not.
I don't think you need to worry about the tires sticking out too far, it will give it a better stance. But like demp said 11.5" is too wide for stock rims unless you get a wheel spacer. I'd say just throw on some 32's instead if its just with a spacer lift.
thirdeye is offline
post #11 of 54 Old 08-05-2010, 03:50 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You don't have money for a suspension lift.but you have money for tubed fenders.
TheBoogieman is offline
post #12 of 54 Old 08-05-2010, 11:59 AM Thread Starter
JustJeepin85
ooops not spacers, i know it doesnt have spacers on it yet i meant backspace i dont have stock rims... not sure what the backspacing is and i cant post pics just yet as i dont have 25 posts up yet... and yes i can afford tubed fenders because i can install, im scared to try to install a lift on it and even more scared to find out how much someone would charge me to do so.
post #13 of 54 Old 08-05-2010, 12:03 PM
thirdeye
putting a lift on is baby cake. you might have problems with rusty bolts because you got a 97, just spray some WD40 or some PB on there
thirdeye is offline
post #14 of 54 Old 08-05-2010, 12:49 PM
olyjeep
I was intimidated to try a lift a while back too but it really is very easy on a Jeep Wrangler, just a few bolts and there are tons of great writeups with step by step instructions, that certainly helped me. 4x4xplor.com has a great BB writeup.
As previously posted, hit every bolt with PB blaster for a week before you install and that made things alot easier. We did a lift on my friends TJ and his rear upper shock mount bolts broke and that was a PITA to deal with. But with some PB blaster, possibly some heat, and steady pressure, all bolts will come out well. You can definitely do it yourself
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #15 of 54 Old 08-05-2010, 01:38 PM
MrGipe
2015 JK Wrangler
I'm running 35s on my DD
Now-15 JKU Anvil
Then-02 TJ Patriot Blue
University of Kentucky
MrGipe is offline
stock , tube fenders , 33 , tj , wrangler
Anybody running 33X10.50s? WVjeep94 YJ Wrangler Technical Forum 5 03-05-2009 04:48 AM
4.56 vs. 4.88 for 33x10.50 w/ 5sp ImaginaryFriend TJ Wrangler Technical Forum 6 11-30-2008 09:32 AM
Anybody running 33x10.50 globemaster3 TJ Wrangler Technical Forum 23 06-03-2007 04:55 PM
Anybody running an RE 3.5 Kit and 33x10.50's...? thejafe TJ Wrangler Technical Forum 1 04-02-2005 01:13 AM
Anyone have a pic of 33x10.5's with a 3.75 BS? BNovak TJ Wrangler Technical Forum 8 10-10-2004 10:53 AM
