97 TJ intermittent Starting Problems - JeepForum.com
post #1 of 6 Old 06-12-2012, 07:21 AM Thread Starter
Randomdude735
Wow, I do hate intermittent problems.
I have a 97 TJ 4.0 with manual trans. Intermittently it won't start. I turn the key and nothing, no clicks or anything. There is power and lights but no starter. If I wait a while and try again, it sometimes works. It seems to do this about once every 10 starts or so. Usually when I'm in a hurry, LOL.
It's driving me nuts. Could it be the starter, the clutch safety switch, a solenoid???
Please help
Randomdude735 is offline
post #2 of 6 Old 06-12-2012, 08:06 AM
Jason
Start by disconnecting the wires from the battery and starter and cleaning off any corrosion.
Jason is offline
post #3 of 6 Old 06-12-2012, 08:11 AM
j_niko
2009 JK Wrangler
I would start, as Jason said, with the connector that goes from the battery to the starter. The one in my wife's 2000 rusted through and I didn't know it was going till it was gone...at a bad time of course
2000 - Sahara
1997 - Sahara
j_niko is offline
post #4 of 6 Old 06-12-2012, 01:47 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
When it's not working, hold the key in the start position and have someone tap the starter with a hammer...
Knuckelhead is offline
post #5 of 6 Old 09-17-2016, 07:50 PM
TrivialDig
Im having an isssue similar to this. I have a 98 tj w the 2.5l and the 5 speed. Every once in a while, ill go to start it, and the started will crank and keep cranking, but it wont spark. I let it rest a second, and it will start right up on the next turn. I have been inside and out on this jeep for other projects, the starter and the cables to it are fine, the battery is newer, the wiring everywhere else is good. The only thing I can think of is the fuel filter or the fuel pump. Thoughts?
TrivialDig is offline
post #6 of 6 Old 09-18-2016, 07:26 AM
98TJSE
try just turning key on and off a few times.. let it build up pressure in fuel before cranking.. see if make s a difference.. otherwise its possible the crank sensor.. i know my old 98 2.5 had issue with sensor plug i guess water got in and corroded the connection, when i took it apart it was a bugger to begin with but was corroded green badly, cleaned up contacts, die electric grease , rebuilt the engine, sold it haha
just something to check, the connection is on drivers side under the intake/ firewall area, just dont mistake it for the O2 sensor wire thats close by as sensor is on bellhousing.. if you want something to check
otherwise you can make your own thread instead of hijackign 2 :O
98TJSE is offline
intermittent , solenoid , starter , tj
1998 TJ intermittent starting problems GunmetalX TJ Wrangler Technical Forum 14 09-17-2016 08:11 PM
Intermittent starting Flashman TJ Wrangler Technical Forum 0 11-05-2011 06:55 PM
Intermittent Starting Problems explorerlyon TJ Wrangler Technical Forum 2 06-22-2011 05:10 PM
Intermittent starting problem... squattingdog YJ Wrangler Technical Forum 10 03-27-2007 08:51 PM
91 YJ, intermittent starting problems joe makeup YJ Wrangler Technical Forum 7 11-24-2004 10:11 AM
