97 TJ hesitation/bucking/stutter/rough idle/backfire on initial start up - JeepForum.com
post #1 of 15 Old 08-23-2007, 10:53 PM Thread Starter
zer0321
I've got a 97 TJ with the 2.5L and 5-spd.
It has a funky issue that only occurs right after the engine has been started (warm or cold, it doesn't matter). 150k on the odometer. No Codes are stored.
After starting the engine, the rpm's drop and almost kill the engine. This can be remedied by pressing the gas pedal enough to keep it from stalling out.
If you try to drive the Jeep normally, as soon as you take off the engine starts to hesitate and sputter while backfiring through the intake, which makes a loud pop noise, which continues until you let off the gas.
The only way this can be avoided is to rev the engine past 3k rpms in neutral and then put it into gear and then gradually let out the clutch.
After this has happened once, the Jeep runs pretty well and does not have the issue anymore until the next time it is restarted. Although it does not seem to be misfiring at this point, The only symptom that remains is a very small bounce on the tachometer needle at idle.
This problem is really annoying me, I cannot let anyone drive my Jeep because they don't know how to handle this situation when it occurs.
What is causing this problem?
I've already replaced the plugs, wires, distributor cap+rotor, and air filter...I replaced the front O2 sensor too, I have looked vacuum leaks, and swapped CPS/TPS sensors as well-
None have remedied this issue...Please Help!
Red 1992 Jeep Wrangler - 2.5L/5spd, lifted 4" sitting on 33s
zer0321 is offline
post #2 of 15 Old 08-24-2007, 08:22 AM
Piratejonh
Piratejonh's Avatar
I had the same problem, took me a year to figure out it was the upstream O2 sensor. replaced almost every sensor. Replaced O2 and no more problem. Unfortunately, any of your sensors could be acting up. Do the free stuff first... Gas cap closed and not broke, no vacuum leaks, no cracked header, rotor/cap/plug wires OK, throttle body clean, Idle speed motor clean etc. GOOOOOD Luck!
Jeep took another piece of my finger today...
Piratejonh is offline
post #3 of 15 Old 08-24-2007, 08:35 AM
ElCanon
Hmmm. You said you replaced the O2 sensors? I had very similar issues with my TJ, same year at roughly the same mileage. I replaced both oxygen sensors and the coolant temperature sensor (it regulates the PCM based on coolant temp - it's cheap and I replaced it based on advice I'd heard here), replaced the cap, plugs, and wires, and it solved my rough start and idle problems. The engine runs awesome now. It seems like misinformation from bad sensors was causing the PCM to go haywire especially before the 2.5L warmed up.
Coincidentally, my sensors never threw a MIL (check engine light) code. I confirmed it by looking at the codes on the odometer using the three key turn trick, which simply showed "55" indicating no stored problem codes. Some here have said sensors can run crappy in a TJ a very long time before throwing a code, and based on my experience, that's definitely true. (As it turns out, I discovered around this time that my check engine light didn't even have a bulb in it, so I wouldn't have discovered a code unless the jeep failed inspection. I bought the jeep brand new so I don't know why the bulb was missing.)
ElCanon is offline
post #4 of 15 Old 08-24-2007, 08:59 AM
jgorm
jgorm's Avatar
Most cars do not use the O2 sensors for the first minute or so after start up. This is to allow them to heat up and work properly. Do you have a CAI on it? My guess is that the MAF is reading wrong. (are these jeeps maf based?) You can clean it with electrical or maf cleaner. After a minute or so it will switch to closed loop and base fueling off the O2 sensors instead of the maf. Going WOT will switch back to open loop. I would also double check the timing considering the backfires. It would have to be one hell of a vacuum leak to cause these issues so you would hear it for sure and it wouldn't go away after driving for a bit. The IAC valve is another possible cause of issues (sometimes they heat up and work better), but i would concentrate on the MAF and the timing. (sorry if I'm wrong, I'm a mustang ECU tuner and just got into jeeps so i'm not familiar with their strategies)
jgorm is offline
post #5 of 15 Old 04-29-2011, 06:46 AM
justicemikes
I'm having the exact same problem. Looks like I have a better starting place now! So far I have changed all plugs and wires, installed new manifold and gaskets, Cleaned fuel systems, no luck with these except for the exhaust leak being fixed. Thanks for your help!
justicemikes is offline
post #6 of 15 Old 04-29-2011, 11:52 AM
Jonny Jeep
Jonny Jeep's Avatar
TJs don't use the O2 sensors immediately so if the issue is right off the bat it isn't O2 related.
How old is the battery? Bad batteries can cause idling problems just after starting. First remove the clamps from the battery, then clean the battery clamps and the battery terminals. Bad connections can create similar problems. If the problem still persists charge the battery up and get it properly load tested at an auto store. If it's bad replace it.
Jonny Jeep is offline
post #7 of 15 Old 04-29-2011, 12:25 PM
rlkelley
put some "seafoam" in your fuel.....that stuff fixes everything.. (not really, but its worth a shot)
sounds dumb but that stuff has increased the performance of my jeep, truck, and riding lawnmower !
rlkelley is offline
post #8 of 15 Old 04-29-2011, 02:38 PM
Simpleman50
I had the same problem. It got to where mine didn't even want to start. I took the throttle body off and cleaned it up real good with throttle body/carb cleaner. There is a good detailed write-up somewhere. I had what looked like chunks of carbon build-up coming out of mine. I replaced the TPS as well. Now it runs like a champ.
Simpleman50 is offline
post #9 of 15 Old 04-30-2011, 09:05 AM
justicemikes
My battery is pretty new and ive checked those connections. I will look at the other sensor and the throttle body to start with. thanks guys for the suggestions.
post #10 of 15 Old 12-22-2011, 11:53 AM
tnovak
Having the exact same issue on the exact same car/engine/transmission/year as zer0321.
Did anybody resolve this issue? My plugs, wires, and O2 sensors are all new.
On a possibly related note (but probably unrelated), there is an antifreeze leak from the radiator which is causing some overheating.
Thanks in advance!
tnovak is offline
post #11 of 15 Old 04-30-2012, 02:31 PM
justicemikes
A lot of my issue actually ended up being a hidden crack in my manifold. I replaced it, wires, plugs, and both o2's.
post #12 of 15 Old 04-30-2012, 04:28 PM
tnovak
Mine turned out to be the distributor.
tnovak is offline
post #13 of 15 Old 12-14-2013, 04:58 PM
zer0123
Guest
Posts: n/a
I have the same problem
What was your solution? I've done everything and took it a step further today and replaced the cat and exhaust. Drove great for 20 mins then, the same damn thing starts happening again. I've given up!
post #14 of 15 Old 12-14-2013, 05:01 PM
zer0123
zer0123 is offline
post #15 of 15 Old 12-15-2013, 06:40 AM
noise_maker
It could very well just be the IAC.
Sometimes you can get away with cleaning them to get a little extra life but generally you gotta replace it.
noise_maker is offline
4.0 Hard Start / Backfire / Rough Run after extended idle biasdesign YJ Wrangler Technical Forum 8 09-17-2009 06:18 AM
Rough idle and hesitation with AC on. krawler510 TJ Wrangler Technical Forum 2 10-20-2008 02:17 PM
intermediate rough idle/ backfire 1CleanTJ TJ Wrangler Technical Forum 1 05-26-2008 10:37 PM
Rough idle, hesitation, =anger Zice TJ Wrangler Technical Forum 8 10-20-2006 03:49 PM
Hesitation while accelerating and rough idle boatingncst8fan YJ Wrangler Technical Forum 5 08-15-2006 09:21 PM
