97 tj getting hot after wheeling and 45 min drive home on interstate - JeepForum.com
 1Likes
post #1 of 19 Old 08-20-2017, 10:24 AM Thread Starter
Bubie1415
I bought a 97 tj completely stock 3 weeks ago. I have added alot of upgrades 3" lift, steel bumpers fenders 33's. I know it's alot of added weight. I hit the trails yesterday had a blast with no issues. On the way back home I noticed the Motor started to get hot on my 45 min ride back home. I have thought about getting the poison hood louver. Has anybody had issues like this with their jeep and has anybody ever used these hood louvers and if so did you notice a difference?
Bubie1415 is offline
post #2 of 19 Old 08-20-2017, 04:21 PM
biffgnar
biffgnar's Avatar
Hood louvers are a decent mod but not to help engine temps. They accomplish different goals. If you have an overheating issue that needs to be diagnosed and addressed directly.
biffgnar is online now
post #3 of 19 Old 08-20-2017, 04:25 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
What type of wheelin' were you doing? Any chance the radiator fins are blocked by mud?
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is online now
post #4 of 19 Old 08-20-2017, 04:34 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What transmission do you have?
Filling in your profile will help with questions like this...
Knuckelhead is offline
post #5 of 19 Old 08-20-2017, 05:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, check the radiator fins. They could be blocked with mud or dirt.
Jerry Bransford is online now
post #6 of 19 Old 08-20-2017, 05:38 PM
Loukaps
Hood louver won't fix that you have another issue that needs to be fixed. I would check your fan clutch.
Loukaps is offline
post #7 of 19 Old 08-20-2017, 07:57 PM
mukluk
How hot was the engine getting?
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #8 of 19 Old 08-21-2017, 08:12 AM
Jerry Bransford
Administrator
X2, hood louvers aren't the fix nor will they help an engine that is overheating.
post #9 of 19 Old 08-21-2017, 10:42 AM
JimSmith
Fan clutch doesn't really have much to do with over heating at highway speed.
Blocked air flow through the radiator, low coolant level or faulty thermostat would.
How hot did it get?
'98 Chili Pepper 2.5, AX5, 33x12.5x15, 5.13, D30 Aussie, Super 35
JimSmith is offline
post #10 of 19 Old 08-22-2017, 05:21 AM
Loukaps
My failed fan clutch only ran warm when running over 65 mph on days over 80 degrees. Replaced fan clutch and hasn't run a lick over 210. I forgot the fan clutch has nothing to do when going highway speeds..
Loukaps is offline
post #11 of 19 Old 08-23-2017, 08:41 AM Thread Starter
Bubie1415
Sorry everyone I haven't been on to post lately I have been super busy with work not sure what kind of transmission I have but I will check into that. We were out at jeep ranch in ocala florida there quite a bit of mud a little bit of crawling rocks not much though. I did drive down the interstate lastnight and my temp gauge did barely creep above one ten. I will check into the fan clutch and thank you for y'all input. I will work on filling out more on my profile sorry new to all this first time jeep owner. Finally. Wanted to be in the jeep family for along time just couldn't swing it financially.
post #12 of 19 Old 08-23-2017, 08:45 AM Thread Starter
Bubie1415
Oh and to answer the question about the temp it was just passed 210 not sure exact number but it was passed it when I got off the interstate. Soon as I turned off jeep didn't want to go over 35 until it cooled down. I let it sit for 20-30 min and I haven't had an issue since.
post #13 of 19 Old 08-23-2017, 08:47 AM
Loukaps
Do you have a big winch up front?
Loukaps is offline
post #14 of 19 Old 08-23-2017, 08:48 AM
jeff_in_rc
Bibie1415, what kind of tranny as in auto or stick.
It crept over 110??? Don't you mean 210???
Check and clean the fins and see how it does then.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #15 of 19 Old 08-23-2017, 09:23 AM
Shark_13
When was the cooling system last flushed?
How old is the water pump and fan clutch?
Hopefully you have the proper thermostat (195F non fail safe, Mopar or Stant superstat) and a new 18lb cap.
Shark_13 is offline
