97 TJ - Fuse Identification - JeepForum.com
post #1 of 8 Old 03-15-2009, 12:43 AM Thread Starter
Airdoc
Got a few things that are not working on the TJ and thought I'd open the fuse box that is under the hood.
I noticed that one fuse is blown (who knows what it is for) and a few fuse locations that are empty.
Aside from this, the 3rd brakelight is not working nor the interior light.
Would anyone have a link or diagram for both the fuseboxes so I can research/diagnose?
I've searched, but can't find.....Thanks in advance!!
97 TJ, 88 M3, 95 M3, 96 328I Track Car, 00 F150
Airdoc is offline
post #2 of 8 Old 03-16-2009, 04:22 AM
Jonny Jeep
Jonny Jeep's Avatar
If the high level stop lamp is the only one not working then it's probably the bulb. The dome lamps are powered from fuse 17 (10A) under the hood.
Here's some pics from the owners manual...
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is online now
post #3 of 8 Old 03-16-2009, 06:12 AM
g-town ram
g-town ram's Avatar
Airdoc,
YOu may want to look on the other side of the engine compartment,
The poster that sent you that Info is in the UK with a right hand drive TJ.
Just a Heads up.
97 Black Sahara
(OlllllllO)
g-town ram is offline
post #4 of 8 Old 03-16-2009, 03:37 PM Thread Starter
Airdoc
Originally Posted by g-town ram View Post
Airdoc,
Just a Heads up.
Thanks....I need a factory manual..if only I could find one.
Airdoc is offline
post #5 of 8 Old 03-16-2009, 04:51 PM
Rubicon_Rob04
I bought one from Collins Brothers Jeep in Texas. Good thing is they have a website, bad thing is they are around $40.
Rubicon_Rob04 is offline
post #6 of 8 Old 03-16-2009, 07:12 PM Thread Starter
Airdoc
Yowsa....I was meaning I'm looking for a Factory Service Manual - that thing is $160 at Collins Bros....I gotta find one, but at that price I'll just wing it.
Airdoc is offline
post #7 of 8 Old 03-17-2009, 02:28 AM
Jonny Jeep
Jonny Jeep's Avatar
The fuses are all in the same locations in the two boxes. The only difference regards these things is they are located on the other side of the vehicle. Airdoc, Have you checked your other brake lamps. The center lamp is fed direct from the brake switch and the left/right sides are fed through the turn signal switch on US models. If the other lamps are working the bulb is the most likely cause with that problem. The dome lamps are still fuse 17 in the PDC, which should also cause your radio to lose station memory.
I've modded the diagram in the center of the middle picture so as not to cause confusion to those with LHD TJs.
post #8 of 8 Old 03-18-2009, 11:00 PM Thread Starter
Airdoc
U da man......thanks!!
Airdoc is offline
Blowing fuse - ing lps fuse gottheanswer YJ Wrangler Technical Forum 12 09-02-2011 08:38 PM
Fuse Amp Identification Question WarPony YJ Wrangler Technical Forum 2 04-12-2009 11:21 PM
Fuse 28 = clutch overide; fuse 24 = ? rdhclark TJ Wrangler Technical Forum 1 03-01-2009 11:22 AM
Fuse Box Question (Not Fuse 4) tj99 TJ Wrangler Technical Forum 1 10-08-2007 10:57 AM
Off Road Fuse in Underhood fuse box attypass TJ Wrangler Technical Forum 4 02-11-2005 02:35 PM
