97 TJ Emerg/Parking brake lever removal help - JeepForum.com
post #1 of 5 Old 11-23-2008, 07:07 PM Thread Starter
rnestved
Alright, went out with like 30 min of daylight left to change out my e-brake lever. Could not get the rubber boot off . I have the mini front console, and the e-brake lever is shrouded in a rubberish boot. How in the world do I get the boot off. My worthless Haynes manual dose not give any good info for this. Appreciate the input.
rnestved is offline
post #2 of 5 Old 11-23-2008, 08:49 PM Thread Starter
rnestved
any ideas??
rnestved is offline
post #3 of 5 Old 11-24-2008, 07:00 AM Thread Starter
rnestved
IS it hard to upgrade to a fuller console and ditch the rubber boot?
rnestved is offline
post #4 of 5 Old 11-24-2008, 07:10 AM
RLD831
RLD831's Avatar
I just stretched the front of mine off, then the back and it will slide right over the handle. If you still can't get it and you're replacing it with a console anyway, just cut it off. The hardest part is the bracket under the boot. You will need one with the side bracket also so you can bolt the console into it. You have to take the entire e brake handle off to do it.
RLD831 is offline
post #5 of 5 Old 11-24-2008, 07:38 AM Thread Starter
rnestved
Thanks, I appreciate the help.
rnestved is offline
parking break lever coming undone GRN_BEAST95 YJ Wrangler Technical Forum 12 07-12-2009 12:45 AM
Blinker lever removal--problems mytjtoy TJ Wrangler Technical Forum 6 06-23-2006 11:31 AM
Brake Chime w/Emerg. Brake Question jtstj TJ Wrangler Technical Forum 10 02-24-2006 06:23 AM
seat lever removal? TAMUJeep TJ Wrangler Technical Forum 2 06-03-2005 05:20 AM
parking brake cable removal? river rat TJ Wrangler Technical Forum 5 12-29-2004 10:51 AM
