97 TJ Drivetrain/ WIRING HELP PLEASE!!! - JeepForum.com
post #1 of 5 Old 08-05-2010, 05:42 PM Thread Starter
MBSCWranglerX
OK....I have a 97 TJ 4.0 I6 MOTOR and TRANNY....and I have a "custom" for lack of a better word, body. The front clip (hood and fenders) are from a 70's model, and the windshield on back (INTERIOR, etc) is from an 86 CJ.
My problem is WIRING. I want to purchase a wiring harness and factory gauges.
I want to purchase the factory dash with factory gauges for the 86 CJ....WHICH WIRING HARNESS WILL I HAVE TO USE? The one for the Drivetrain or the one for the Interior Dash???
PLEASE HELP!!!!
Also, if anyone can tell me how to manually wire up my Headlights, Tail lights and turn signals....GREATLY APPRECIATED!!!!!
MBSCWranglerX is offline
post #2 of 5 Old 08-05-2010, 07:39 PM
George Dickel
George Dickel's Avatar
Due to the fuel injection system, I think you will need to run the '97 harnesses, at least for engine management purposes.
As of last year, aftermarket harnesses for the TJ are not available and the dealer charges waaaay too much to be an option. Locating harnesses for a fair price has become kind of difficult. Many junkyards will have them listed in their inventory but will not have it in stock when you call. I have some various harnesses left over from my build and will have to look to see if I have anything for your build. I probably do. Sounds like you will need a PCM too and I can put you on a good source for that.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #3 of 5 Old 08-05-2010, 07:42 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
when you say "70s model" do you mean 70-75 or 76-79?
Mail crawling.
MisfitSeven is offline
post #4 of 5 Old 08-05-2010, 08:14 PM Thread Starter
MBSCWranglerX
Update
76-79
post #5 of 5 Old 08-05-2010, 08:19 PM Thread Starter
MBSCWranglerX
Additional Info
To give more detail.....all I have WIRED right now is a push button igniton button, a kill switch, and the windshield wipers. All I want, in addition to these, is the speedo, tach, temp, oil pressure, volts, and fuel gauges...
wiring , harness , tj , wrangler
99 4.0 drivetrain into YJ louieberner YJ Wrangler Technical Forum 1 02-16-2009 02:36 PM
chevy drivetrain conversion wiring problem volks YJ Wrangler Technical Forum 1 12-09-2008 02:10 PM
Will an '86 Cj7 Drivetrain fit in my Yj? driveajeep812 YJ Wrangler Technical Forum 2 11-25-2008 05:54 AM
4.2 drivetrain to 4.0 + ax-15 OR 4.2 to ax-15? Brendan YJ Wrangler Technical Forum 1 02-08-2002 05:06 PM
Drivetrain AirborneJay YJ Wrangler Technical Forum 1 05-22-2001 04:11 PM
