97 TJ - Cant Ground My AMP to Chasis - JeepForum.com
post #1 of 5 Old 05-06-2012, 08:01 AM Thread Starter
Dombrowski95
Hey,
Im currently installing an audio system in my 97 TJ. Ive had this problem in the past, however, just ran a wire to the (-) on my battery. However, I cannot afford 17ft of 4 GA wire at the moment. The problem is that when installing after market parts that require elec. , the chasis of my jeep wont ground the wire..
Maybe im just a little challenged, but can someone point me in the right direction.?!
-Thanks
Dombrowski95 is offline
post #2 of 5 Old 05-06-2012, 08:05 AM
stu132u
[QUOTE=Dombrowski95;13524535]Hey,
-Thanks[/QUOTE
I have two amps (four channel for the sound bars, and a mono for the subwoofer) installed on my 2001 TJ and I' connected the ground to the bolts that hold down the front seat brackets - no issues. They both fire up fine, and the sound is great! I will caution you to make sure that you run the power line to the amplifier away from the speaker wires - minimizes/eliminates the feedback.
stu132u is offline
post #3 of 5 Old 05-06-2012, 08:06 AM Thread Starter
Dombrowski95
Thanks alot, ill try it
post #4 of 5 Old 05-06-2012, 08:08 AM
Ironhead
add the signal wires to that list, power down one side, signal and speaker down the other
Ironhead is offline
post #5 of 5 Old 05-06-2012, 08:14 AM
stu132u
Good call on the signal wires too! I ran my power lead between the seats under the center console and the speaker wires down the passenger side exterior wall. Of course, you could always run the power down the side and and the speakers down the middle.
stu132u is offline
ground , jeep , system , tj , wire
Things lodged in your chasis bogleparsons Wrangler General Discussion 8 04-24-2012 12:47 AM
YJ body on a TJ chasis 69junk YJ Wrangler Technical Forum 2 10-03-2009 07:22 AM
Chasis coating ScJeepaholic TJ Wrangler Technical Forum 2 04-20-2009 12:51 PM
What year is the best rolling chasis p3ripperfw YJ Wrangler Technical Forum 3 09-02-2007 11:58 AM
90 YJ chasis ? 90dreams YJ Wrangler Technical Forum 2 12-07-2005 10:14 AM
