97 tj aw4 swap need wiring help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 97 tj aw4 swap need wiring help
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiFree shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.
Unread 12-31-2010, 09:37 AM   #1
rparker12345
Im neck deep in my swap project. I bought a 2000 aw4 trans. from a local salvage yard. I later found out I needed some parts but they crushed the vehicle. I didnt come with with the black and grey wiring connectors. I found another yard that had a 97 cherokee 2wd. I grabbed the tcm and connectors. Now finding out that the 97 cherokee and 2000 cherokee are different. The 97 has pins missing on the 26 wire plug. For example pin 1and 2which would be for an input sensor. Pin 3 is missing which would be for the one of the two wires for the output speed sensor. If anyone has any knowledge of how to wire the input speed sensor for a 97 or did the 97 have an input sensor? After reading so many wiring diagrams, my head is mush. Thanks for any help.
rparker12345 is offline   Reply With Quote Quick reply to this message
Unread 12-31-2010, 09:47 AM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Mrblaine and I worked several nights getting the wiring right for an AW4 conversion for a King of the Hammers race vehicle and it wasn't easy since the wiring and wiring color changes by model year. It took the several pages of wiring diagrams we had plus lots of phone calls to someone else who had access to online wiring diagrams before it finally came together but, again, it wasn't easy. Be especially careful that you have your frame and signal grounds done correctly. We had a problem with one of those that caused a later issue.
Stu has several AW4 conversion projects on his website at http://www.stu-offroad.com/siteindex.asp and at least one of them has some wiring information that would help. That's the best help I can offer since I no longer have any of the wiring information we used on the earlier conversion.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 12-31-2010, 11:08 AM   #3
mike481
I know from doing my AW4 swap that the wiring changes from 98' up. When I was getting parts together I got a TCU and connectors from a 97' AW4 and they would not work with the wiring harness I had already made.
This is the link to Tim Doumit's AW4 swap on Stu's site. He had a 97' and the wiring should be the same as yours.
http://stu-offroad.com/engine/aw-4a/aw-4a-1.htm
Worst case you can use Stu's wiring list to cross reference the wires to your 97'
http://stu-offroad.com/engine/aw-4/TJ-AW4WiringList.pdf
If I was you I would look for the black and gray connectors from a 98-01 XJ. This way the wires at least match across the connectors. With these you could get your wiring complete. I have wiring diagrams from multiple years so I'll see what I can find for you.
It's a great swap and I love mine. Other than goofing off in the snow I haven't had a real chance to go off road with it yet.
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline   Reply With Quote Quick reply to this message
Unread 12-31-2010, 04:56 PM   #4
rparker12345
Thanks for the help. Im looking locally for a 98 and up at the upull it yards. I jumped on the 97 thinking it was an obd11 and wouldve been the same. Im all over stu's site. The wiring on his pertains to a 2000 aw4 and tcu. I also have a membership to alldatapro. So I can look up whatever vehicle's wiring. The 97 and 2000 are definately different. I will keep on studying. Thanks again and any suggestions will be appreciated. Jeep On!!!
Unread 12-31-2010, 06:20 PM   #5
durango-bob
There are some on line wiring diagrams available at GreatLakesXJ.com in the tech section. This may help a bit.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 12-31-2010, 06:35 PM   #6
Stu Olson
Stu Olson's Avatar
When we did Kruize's AW4, we used the heck out of the alldata web site. He bought a subscription and we looked through a goodly amount of diagrams.
Good luck on the project. If you find something worth adding to the write-up on my site, let me know. We can grow the write-up, so to speak, so other folks can benefit from it.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote Quick reply to this message
Unread 01-21-2011, 02:46 PM   #7
alextremetj
Just wondering how you made out?
I just completed my AW4 swap, and let me tell you, it is worth it!
alextremetj is offline   Reply With Quote Quick reply to this message
Unread 03-11-2011, 02:14 PM   #8
Deacon
Deacon's Avatar
A friend of mine has an extra AW4 lying around in his shop that (I think) should mate right up to my 4.0/241 in place of my 6-speed that needs to be rebuilt. I'm really curious as to how well it worked for you, too.
Deacon is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 02:33 PM   #9
laxdadof3
hello, I am going to do the aw-4 swap is there any place where we can get a parts list for the entire swap?or if any company sells a complete
kit for the swap?
laxdadof3 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:32 PM   #10
Stu Olson
Stu Olson's Avatar
What you need can be found in this AW-4 write-up. There are several articles on my site.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Unread Yesterday, 09:14 PM   #11
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Welcome back...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:16 PM   #12
Stu Olson
Stu Olson's Avatar
Hi.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Unread Yesterday, 11:13 PM   #13
Knuckelhead
AFSOC Retired
Hi.
How long before you move back to where the mosquito is considered the state bird?...
Unread Today, 08:16 AM   #14
Stu Olson
Stu Olson's Avatar
We'll be leaving AZ around the 1st of May, maybe a little sooner.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
